  • SN95 4.6L Mustang Tech
PLEASE HELP!!!! Brake light issues!!!
  • Thread starter Thread starter 2KSLOSTANG
  • Start date Start date Jan 22, 2023
2KSLOSTANG
  • Jan 22, 2023
Hey everyone new guy here! I have a 2000 GT Coupe and I’m having issues with the brake lights I have already changed the brake light switch and checked fuses but my issue is I have power at fuse 33 but no power at fuse 41 but if I turn the key on I get 10.5 volts at fuse 41 and 10.5 volts at the switch and I have hyper flash with my turn signals what could be my issue thanks for any help and information!!!
Shuttleman83
239
USA
Jan 22, 2023
  • Jan 22, 2023
Multifunction Switch might be a good start or the wiring to it.
Admin Dude
Jan 4, 1985
43,418
21,622
234
Box behind Walmart
Jan 22, 2023
  • Jan 22, 2023
The ignition switch is also suspect.
2KSLOSTANG
  • Jan 22, 2023
Yeah I was reading something about the multifunction switch so I’m gonna order one and change it and see if that would be the problem.
2KSLOSTANG
  • Jan 22, 2023
Really the ignition switch I haven’t seen anything about that on anything I have read and it seems to function properly?
Shuttleman83
239
USA
Jan 22, 2023
  • Jan 22, 2023
Use a test light and or multi meter and check out the ignition switch.
2KSLOSTANG
  • Jan 22, 2023
Where would I even bring to start testing the ignition switch when I turn the key on everything works as should with key power
Shuttleman83
239
USA
Jan 22, 2023
  • Jan 22, 2023
KOEO, test light to ground, multi meter would be a great start. You said 10.xx voltage at fuses they should be around 12 or so.
2KSLOSTANG
  • Jan 22, 2023
Ok what is KOEO sorry not familiar with that term
Shuttleman83
239
USA
Jan 22, 2023
#10
  • Jan 22, 2023
  • #10
Key On, Engine Off where the key is set a certain notch in the tumbler forward but not fully started or on.
2KSLOSTANG
#11
  • Jan 22, 2023
  • #11
Ok but would that even be an issue seeing that the brake lights work off a 12v constant power and not keyed power
D
Deleted member 38176
Jan 24, 2023
#12
  • Jan 24, 2023
  • #12
Is this an auto car?
2KSLOSTANG
#13
  • Jan 25, 2023
  • #13
No it’s manual
2KSLOSTANG
#14
  • Jan 25, 2023
  • #14
No it’s manual
manicmechanic007
5 Year Member
Sep 26, 2017
2,554
724
143
Roy, Utah
Jan 25, 2023
#15
  • Jan 25, 2023
  • #15
You better check the sockets and all the bulbs (first)
You have ground back feeding somewhere
Take all the bulbs out and install just a couple then check it again
When the sockets fail strange things happen sometimes
Check the brake light switch connector for a broken wire (the wires bend back and forth when hitting the brakes)
The wires break inside the insulation
manicmechanic007
5 Year Member
Sep 26, 2017
2,554
724
143
Roy, Utah
Jan 25, 2023
#16
  • Jan 25, 2023
  • #16
Post 2 is a good one
The wires sometimes get pulled out (or partially out) of the multifunction switch
Worse when using the tilt a lot
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
