Please Help, I'm at a Loss :(
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Okay guys... My 89GT has the strangest problem- Sometimes she starts and sometimes she don't, cuts out driving too sometimes. It also starts to hesitate very slightly the drive before the next time it doesn't crank. Starter turns the motor but no crank over. Maybe an hour, day or week later it cranks again for a day, week and hesitates and does it again. Sometimes it cuts out while idling and driving. Also, the fuel pump does come on. I'm getting 40psi fuel pressure at rails.
My Mods:
*Explorer Intake
*Cam (dunno what kind, was in there when I bought it- heads look stock and have a 'T' on them)
*MSD 6al
*Blaster Coil
*Cold air intake
*Some kind of really stiff racing clutch
*Adjustable clutch cable (at firewall)
*The rest is exhaust & gears & such
What I've done to fix this problem:
* Checked Timing- Twice at 13
* Coil- current is New Blaster, tried 2 brand new
* Distributor- New remanufactured
* Control Module- New
* Starter solonoid- New
* TPS- New
* Idle Air Bypass- New
* Alternator- New
* Fuel Pressure Guage at fuel rail- (Getting 40psi)
* Battery- New (needed anyway, not related at all)
* Put an extra Ground- From Head to swaybar mount
* Fixed some bad wires at starter solonoid
* Plugs
* Cap and Rotar Button
I'm at a total loss. If it's getting fuel, it wouldn't be that. We checked for spark using the old "screwdriver arch test on the coil wire" and that worked. All of the guages and equipment come on when key turns over. Battery seems fine. Please Help... :bang:
I've seen Mass air slow sensors do similar things when they go out. But your problem sounds very intermittant. Double check the ingnition system ,electrical conections and the vac system.
But to be honest, it really sounds like a fuel pump problem to me
Forgot to mention I have these too
*70mm Throttle Body and spacer
*1" intake spacer
Yeah we checked/fixed all vacuum. Still sounds like we're getting some around the lower intake or the bottom of spacer... but reinstalled it. But if I'm getting 40psi reading could it still be the fuel pump? And yes it is VERY intermitant- I'm afraid to drive this thing anywhere- I've been lucky that it started back up when out and about.
Next time it doesn't start, do this checklist. You will find the problem.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
