PLEASE HELP ! injector / fuel problems ...
jones
91
Miami Florida
I have a 93 mustang gt. The car has spark and it WILL START for a few seconds if i put gas on the air intake until it runs out of gas fumes . The problem is i have no pulse in my injectors. They have power but they have no pulse. I also have no power in my fuel pump. The relay for the fuel pump has power thou. I changed ALL my relays, checked ALL fuses, and changed the computer and fuel pump.
Anyone has any idea what could be causing this problems? :shrug:
Thanks in advanced !!!
The PIP in the distributor is what tells the module then the computer to pulse what injector at what time.It is under 15.00.It sucks to replace though.You have to take the distributor out and get the drive gear taken off to change it.That would have been my 1st guess other then fuel pump relay and the fuel pump cut off switch in the trunk.Oh I hope you checked that.
how is the power supply to the pump and injectors. i think they use the same circuit for power. looks like you may not have juice. check the fusable link....
do you have coil power to the FP relay, or input juice from the fusable link? or both?
good luck and bump.
I will check the PIP if i cant figure nothing else. I got power on the FP relay but very little , i say very little because i tested it with a test light and the light on the bulb was very very weak (i could barely see it sometimes in the shade). The injectors have power and the light on the tester was strong like it should.
Another wierd thing is that i checked the Green/yellow wire on the FP relay that runs all the way to my fuel pump and had no power but the red power wire has! (very weak like stated above) , So i figured if i took off the relay and bridged the red power wire with the Green/yellow pump wire, I WOULD HAVE POWER ON MY FUEL PUMP RIGHT? wrong ! I still wont have power and i can hear the coil wire sparking inside the distrib when i did this. It was going crazy with blue sparks. :shrug:
Question * What and where is the fuseable link?
Thanks to both of you guys!
make sure that all the wires are connected tightly on the hot side if the starter relay thats mounted on the side of engine bay, I had this same problem i had few wires that had a loose connection
If you crank the engine and get a spark at the coil wire, the pip is working...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer
E.) Fuse links in wiring harness
F.) Ignition switch
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing. A Noid light available from Autozone, is one way to test the injector wiring. I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
A.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
B.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
C.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order form the non HO engines.
