please help on A/C now!!!!!!!
  • Thread starter Thread starter rdharper02
  • Start date Start date Jun 1, 2006
rdharper02
like kicking myself in the junk
703
237
84
Jun 1, 2006
  • Jun 1, 2006
I recently bought a recharge kit for my 1993 gt. (It has been converted to 134) I found the low-side connection (according to the kit, the only one that will fit the conector) Its located on the line mounted to the top of the compresor. (If I'm wrong...please let me know.) I hooked the can and gauge up while its running and it shot to the 100psi range almost immediately. According to the company it should read 45psi. Now my compressor kicks on intermittingly. Do I have the wrong connection? Is my sytem over full? Let me know if you guys have anything, so I can use this expensive a** can before it seeps out.
rdharper02
703
237
84
Jun 1, 2006
  • Jun 1, 2006
Anyone?
Jaswir
578
Orlando, FL
Jun 1, 2006
  • Jun 1, 2006
no you have the right connectioin... its the one right above the compressior... do u have the car running while you hooked it up?? if it reads 100psi its over full
rdharper02
703
237
84
Jun 1, 2006
  • Jun 1, 2006
Car was running at the time. The gauge is reading about 65 psi with just the can. If its over full, will it keep the compressor from completely engageing? This is the first project car I've kept A/C on. Sorry if I sound a bit ignorant.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jun 1, 2006
  • Jun 1, 2006
If it was 100 psi on the low side, it would vent itself from the compressor. only way it will read that high is if the clutch on the compressor is not engauging. That high of a reading means the compressor is not engauged.
rdharper02
703
237
84
Jun 1, 2006
  • Jun 1, 2006
any quik tips on how to trouble shoot?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jun 1, 2006
  • Jun 1, 2006
Sure. If you have 100 psi of pressure, THERE IS FREON IN IT. If you didn't have freon, it would read 0. Turn the a/c on full blast, start the car... see if the front part of the compressor is turning with the pulley. This is the clutch. If it IS turning, you've got major problems cause it shoudl never read that high on the low side.
If it's not... first check the low pressure switch (which is located on the cylinder looking thing on the firewall... called the acumulator).. You can do this by checking for 12 volts on both wires to it. If you do not have 12 volts with the a/c on on both wires, the switch is bad. This will not allow the a/c compressor to turn on. Other then that is the a/c clutch relay. It is located under the air intake box. Looks like any other relay. This is known to go bad also and will not allow the compressor to turn on. Good luck, bro!
Nick
rdharper02
703
237
84
Jun 1, 2006
  • Jun 1, 2006
Thanks Nick. I'll get the multimeter out tommorow and give it a check. Any idea on the price of the lp switch and relay?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jun 1, 2006
  • Jun 1, 2006
Both are about 15-20 bucks at your local parts store
rdharper02
703
237
84
Jun 1, 2006
#10
  • Jun 1, 2006
  • #10
Much appreciated
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
