  • SN95 4.6L Mustang Tech
Please help!! Suspension question!!
  • Thread starter Thread starter LoadChrisGT
  • Start date Start date Sep 22, 2004
L
LoadChrisGT
21
Ventura CA
Sep 22, 2004
  • Sep 22, 2004
I lowered my car a couple of months ago(00GT) using eibach sportlines with tokico struts and shocks. After the install i noticed severe negative CAMBER on the front right side and the the left side wasn't as bad as the right but still noticeable. I also installed steeda caster camber plates. I took it to get it aligined and after it was done I still noticed Negative CAMBER on both sides. The tech told me it was in limits so I thought it was ok. About a month later I looked at the tires and they were severly wore down on the inside part(the steel was showing) Needless to say I had to buy 2 new tires and get it aligined again. After they were done they told me that this is the best aliginment they could get because the plates were maxed out on camber. They said the plate that comes from under the strut tower was rubbing the side of the strut tower and that they couldn't move it any further. What can I do to fix this? And did I mess up my suspension? If so what can help me more as far as suspension parts go? Im not driving my car as we speak b/c I don't want to **** it up anymore!! Sorry so long! Please help me!!!
hotrodnut
672
North Florida
Sep 22, 2004
  • Sep 22, 2004
Steeda makes Camber Adjuster Bolts that will give you about another degree per side that sells for around 30 bucks, it's not much more adjustment but it will help some.
Blev
1,295
So. Cal. V-Town
Sep 22, 2004
  • Sep 22, 2004
WTF.....
Now I'm stressing because I'm about to drop my car with some H&R SuperSports and I also have the Steeda CC plates. I thought the CC plates were supposed to fix that
1992 2.3LX
885
Ky
Sep 22, 2004
  • Sep 22, 2004
ok so mark Steeda CC plates off the list to go with my H&R's. what plates should i go with then?
DTMach1
240
Virginia Beach, VA
Sep 22, 2004
  • Sep 22, 2004
go with Maximum motorsports CC plates
Blev
1,295
So. Cal. V-Town
Sep 22, 2004
  • Sep 22, 2004
So do the Steeda C/C plates just suck?
L
LoadChrisGT
21
Ventura CA
Sep 22, 2004
  • Sep 22, 2004
Will steeda 4 bolt caster/camber plates work, b/c I have those sitting in the garage.
R
Rocketman
730
SoCal
Sep 22, 2004
  • Sep 22, 2004
Blev said:
WTF.....
Marlon can align it for you
Blev
1,295
So. Cal. V-Town
Sep 22, 2004
  • Sep 22, 2004
That's what I figured. Shoot me a PM with what he charged you so I know what to expect.
L
LoadChrisGT
21
Ventura CA
Sep 22, 2004
#10
  • Sep 22, 2004
  • #10
Whose Marlon and where is he located? Does he install plates also?THX
Blev
1,295
So. Cal. V-Town
Sep 22, 2004
#11
  • Sep 22, 2004
  • #11
WHOA...
Just noticed your in Ventura, sweet. You should come to one of our GTG's. Marlon is the President of All Mustang and Ford of Southern California. He has an alignment shop about an hour from us. Real nice guy and does great work. We have a few Ventura County threads in the West Coast forum, you should check them every now and then to see what's up in your back yard.
R
Rocketman
730
SoCal
Sep 22, 2004
#12
  • Sep 22, 2004
  • #12
Yes!
He will do installs for all suspension and has an alignment rack there in his shop as well
http://www.fly-ford.com/
hotrodnut
672
North Florida
Sep 23, 2004
#13
  • Sep 23, 2004
  • #13
I have the Steeda 4 bolt Billet Aluminum style plates and they work fine for alignment. I used the MRT Race springs which lower the Mach1 as much (or more) as the eibach sportlines do. There is plenty of adjustment for Camber and Caster. You do have to cut the thickness of the rubber on top of the stock shock dust boot to be able to get the necessary travel for the adjustment.
I installed some J&M 4 bolts plates on my sons GT and had to remove the shock dust boots completely to get enough adjusment to align it properly after lowering it 2".
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
