Please Help!! Voltage issues or so I think...
  • Thread starter Thread starter MustangMatt1966
  • Start date Start date Sep 29, 2009
First Prev 2 of 2
MustangMatt1966
1,004
Orlando Fl.
Oct 3, 2009
#21
  • Oct 3, 2009
  • #21
Ok, so update.
Replaced the fuel sending unit, fuel filter and fuel pump. Test drove it and the issue crept back although the fuel level in the filer looks much better than before. On the way home (15 min drive) the issue did not happen at all.
I am so confused. We drained the tank and there was not a lot of crud or anything of the sort.
What we did do was take the gas cap off and tape over the opening to see if there was some sort of vapor lock for the 15 min drive back and the issue didnt happen. Could it be something like that?
68er - That might be the next step to go to the ignition system but I am getting tired of throwing money at the car and my wallet keeps getting lighter.
Let me know what you all think? The issue is so random and sparatic I have no idea but my frustration level is building...
sparky
20
#22
  • Oct 5, 2009
  • #22
Quick question for you. Do still have your resistor wire in use or did you bypass it? Reason I'm asking is that I had similiar problems, turned out the resistor wire was getting hot & increasing
in resistance. So if you already bypassed it since you have electronic ignition, you might try that.
G/L, sparky!!!
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 5, 2009
#23
  • Oct 5, 2009
  • #23
Good call sparky, I was just about to ask that.
Also, if you want to take the fuel tank completely out of the mix, buy some rubber hose and run it off of a gas can. You can put the gas can behind the drivers seat and pop the body plug out. There should be a rubber fuel line on the drivers side that joins 2 sections of hard line together. You can plug the hardline from the tank and feed the hard line going to the engine with the rubber line that comes through the body plug. Remember to clamp everything and also this is just for testing purposes ! Don't run your car like this perminately as its REALLY unsafe !
MustangMatt1966
1,004
Orlando Fl.
Oct 5, 2009
#24
  • Oct 5, 2009
  • #24
G/L, sparky!!!
Hey Sparky, excuse my ignorance or stupidity but resistor wire? Where is this located and what is the purpose of the wire. The motor was installed and built by a performance shop so I really don't know what they did or how it was wired.
Any information you can provide will aid in locating this wire and working on a bypass. How do I go about a bypass of this wire?
sparky
20
#25
  • Oct 6, 2009
  • #25
The resistor wire is on the ignition switch, I think that it's pink. If if hasn't been bypassed, then I'd do it since you're running electronic ignition.
First Prev 2 of 2
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
