please help :\
  • Thread starter Thread starter tegra
  • Start date Start date Oct 25, 2007
T
tegra
  • Oct 25, 2007
I know yall are going to be like WTF its in the wrong spot, but I need help
It's my lifeeee, and I want some opinions from you guys before I take her into the shop :\
http://forums.stangnet.com/showthread.php?t=725378
Okay, so I was driving home from a school football game and the car started popping (back firing i figure) and then it just cut off, the lights and stuff stayed on, im pretty positive the radio did too. But I pulled off called my dad, he came and met me and after awhile it cranked and I drove home while he followed me, and it looses power and when you rev it up it cuts out.
I got a new fuel pump, replaced the spark plugs and spark plug wires, cleaned out the catalytic converter.. Anyone know what the problem could be?
It's a 1993 2.3 LX
bloopbloob
578
Alberta
Oct 25, 2007
  • Oct 25, 2007
i'm pretty curious how you cleaned your catalytic converter.....???
any chance your distributor hold down bolt is loose?
HISSIN50
34
129
Oct 25, 2007
  • Oct 25, 2007
I'm not sure how you cleaned the cat but based upon what you've said, that's not the issue anyhow.
I would take the ignition module in to a parts store and have it repeatedly bench tested.
Good luck.
T
tegra
  • Oct 25, 2007
My dad cut the pipe infront of it and took all the stuff that was in it w/e it was out while i was in school and welded it back together
It's not the ignition, don't have a distributor.
Any other suggestions?
HISSIN50
34
129
Oct 25, 2007
  • Oct 25, 2007
You have an ignition and you should have an ignition module. The test is free and is where I'd start, absent any codes or other info.
Good luck.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Oct 25, 2007
  • Oct 25, 2007
maybe a fuel filter?
i had a problem with sputtering and such a while back and it was my O2 sensors...something to consider
do what HISSIN said first and get back to us though
baldy1
124
Portsmouth Va
Oct 25, 2007
  • Oct 25, 2007
Have you check for codes yet. Check for codes before you start throwing parts at it. That can get expensive. Codes first then check back
Bottomlesspit
I started the longest tech thread in the known uni
2,636
Del Rio, TX
Oct 26, 2007
  • Oct 26, 2007
Follow the above advice so you don't throw wasted money at it trying to hit the elusive bullseye. I do agree about checking the fuel filter. Crud in a dirty filter will get stirred up as you drive and slowly clogg up the outlet. After the car shuts down the crud slowly settles and the port opens back up, only to repeat again when stirred up.
Get your codes read...Auto stores routinely do that for you now.
The ignition module on the front of the distributor can also cause your kind of trouble, just as Hissin said. If you end up with a new one, make sure it's a FORD brand, not one from Auto zone! IF not, you will be sorry in the long run.
Good luck to you, hope to hear back from you with your results.
Ken
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 26, 2007
  • Oct 26, 2007
Sounds like a timing belt jumped
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 26, 2007
#10
  • Oct 26, 2007
  • #10
You should definately check for any codes. You may have codes and no check engine light. Even though its a 2.3 with the distributorless ignition there is still an ignition module. It is different than the TFI module on a 5.0 and looks to be much more expensive so I'd definately have it tested before replacing it.
Hickfied
413
Morganton, NC
Oct 26, 2007
#11
  • Oct 26, 2007
  • #11
So the engine breaks up? Does the tach jump around, acts funny?
There is an ignition module bolted to the front of the intake; When looking at the engine from the front, it will be on the right, and if original it will be labled "DIS". It will have a harness connecting to it at the top and bottom. Remove it, and have AutoZone repeatedly check it atleast 5 times in a row to get it hot. I will bet that is your problem, it is the #1 problem with DIS 2.3's.
T
tegra
#12
  • Oct 26, 2007
  • #12
My cars the version after the distributer, i guess since I don't have one
I did take the gas tank off and we looked at the fuel filter it looks fine, I guess all I need to do is go get the codes read.. but the check engine light isn't on
HISSIN50
34
129
Oct 26, 2007
#13
  • Oct 26, 2007
  • #13
Codes can be stored without illuminating the CEL.
You do not have an inline fuel filter? Or did you look at the pump's sock?
You need to monitor pressure when it acts up.
A repair manual is very helpful for familiarizing one's self with the systems in the vehicle.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 27, 2007
#14
  • Oct 27, 2007
  • #14
Some help with dumping the codes...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
skunk21
1,203
Taxachusetts
Oct 27, 2007
#15
  • Oct 27, 2007
  • #15
you might also want to try posting this in the 2.3l tech section. not saying these guys can't help but the 2.3 guys play with those motors all the time. might be worth a shot.
Help Identifying Engine Harness Plug
  • FoxbodyRob
  • Feb 7, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Feb 7, 2026
FoxbodyRob
  • Locked
Engine Help timing possibly
  • K1tha1
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
  • dan50
  • Jul 18, 2026
dan50
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
