  • SN95 4.6L Mustang Tech
plenum and TB question
  • Thread starter Thread starter blockhead
  • Start date Start date May 27, 2004
blockhead
69
  • May 27, 2004
if i just get a TB for now can it be bolted on to a stock plenum? same for a plenum can it bolted on to the stock TB? if so will i see any gains with just one part upgraded? or would it be better to get the hole thing done at the same time?
trinity_gt
3,125
81
99
Canada
May 27, 2004
  • May 27, 2004
A 70mm TB will probably fit the factory plenum though the plenum really should be "ported" to smooth the transition from the 70mm TB to the 65mm plenum bore. To be honest though, the TB is not really the problem on the modular: the plenum is the worst offender. You'd be better off getting a new plenum and using the stock TB than going to a larger TB and staying with the stock plenum.
I just bolted on an Accufab plenum and 70mm TB and am very, very happy with the combo
blockhead
69
  • May 27, 2004
thanks. thats exacly what i wanted to hear. its a plenum for me. so how was the differance? did you FEEL it pull better? at what RPM's did you feel the differance?
KaPPaBaLL
1,326
BAYAREA
May 27, 2004
  • May 27, 2004
yes, just the plenum itself will net you more SOTP gains then a TB will. Never get a bigger TB unless you are planning on swapping for an after plenum as well. I chose to go with the C&L plenum and Accufab 75mm TB. That's only because i got them cheap as fawk. goodluck
trinity_gt
3,125
81
99
Canada
May 27, 2004
  • May 27, 2004
Well, I don't really trust my own SOTP meter all that much. Having said that, the car feels torquier to me, especially down low. Throttle response is definitely better. The intake noise changed to a more gutteral, low-frequency growl (the FIPK helps this). It feels like it pulls harder in 3rd & 4th at WOT on the highway. It's not a supercharger though and didn't transform the car by any means.
I hope to try to dyno it soon, maybe this weekend. If I had to venture a WAG I'd estimate perhaps 8HP and a similar torque gain. Really though, I'm interested in area under the curve on this one; I want to see if what I think are good gains down low is real or just placebo.
blockhead
69
  • May 27, 2004
thanks guys good info. i think im going with Accufab plenum myself. i got cought up on the plenum test hype. but will get a Accufab 70-75mm TB later. just curious what is the stock idle? i only have a MAF and im at 750 or so. is that normal? or should i mess with the idler?
KaPPaBaLL
1,326
BAYAREA
May 27, 2004
  • May 27, 2004
your idle is fine don't mess with it.
Steeda2004GT
98
Daytona Beach, Florida
May 27, 2004
  • May 27, 2004
Hey Blockhead, can you keep me updated on how the Accufab performs and such? I was going to order that instead of my Mac CAI, but I changed my mind. It's next though. Good luck with your new purchase.
Satin Silver GT
127
Sagamore Ma.
May 27, 2004
  • May 27, 2004
Went with the Accufab plenum and their 70mm TB. Better throttle response, and can really feel the difference pulling past 3,500 RPM.
01MineralgreyGT
46
Old Bridge N.J.
May 27, 2004
#10
  • May 27, 2004
  • #10
June 2003 issue of muscle mustangs & fast fords
In the June 2003 issue there is an article on page 116 about this issue. with a Mac products 70mm TB and a ported upper intake plenum it flowed 530 CFM (that is 64 CFM over stock gain) and a 10 horsepower & 14.9 ft lb of torque gain which I believe is well worth it and is pretty cheap at MORGAN MOTORSPORTS (818)342-5693 you can get more info it costs 159.95 to port the plenum and a refundable 59.95 core charge
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
