  • SN95 4.6L Mustang Tech
Plenum install questions
  • Thread starter Thread starter montman
  • Start date Start date Apr 14, 2005
montman
447
Hampton Roads, VA
Apr 14, 2005
  • Apr 14, 2005
Just installed a dragon upper plenum
no probs on the install at all.
But: did my throttle cable have this much slack before?
It sure didnt seem so, but perhaps im wrong.
It seems like a can push it down and it will move over a half-inch.
Im def. getting WOT as i checked that manually, its just seems really slack when its coming back.
Also seems like there is almost a squeek when im getting on it.
Is that just the air intake or perhaps a bolt is not properly torqued?
Just checking to see if anyone else has these issues.
thanks
C
chimchim
267
PA
Apr 14, 2005
  • Apr 14, 2005
no probs on the install at.
It sure didnt seem so but perhaps im wrong.
Im def. getting WOT as i checked that, its just seems really slack when its coming back.
thanks
If you're getting WOT, then it's routed correctly. I thought the same thing when I did mine. The thing is, you never got under there and messed with it before and now you think there's a lot of slack in it, which there is. Also, the "squeek" is just a suction noise with the increased air velocity. I wish mine was louder. hahaha
montman
447
Hampton Roads, VA
Apr 15, 2005
  • Apr 15, 2005
Thanks - thats exactly what my buddy said on both counts.
Just wanted to hear it from someone else that did it.
T
Torinalth
952
Clayton NC
Apr 15, 2005
  • Apr 15, 2005
hey, just wanted to confirm for ya as well.. did my dragon TB/plenum some last thursday, and i noticed the same thing, throttle cable was slacked, but when the pedal was down the TB plate was flat. the squeak is the vaccume being broken on the TB blade ... i got it too
Torinalth
C
chimchim
267
PA
Apr 15, 2005
  • Apr 15, 2005
check this out: http://www.mustangworld.com/ourpics/fcar/99pedals.htm
I did this with a 3/4" piece and it makes a world of difference.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 7:26 PM
Kleinjj27
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
