  • SN95 4.6L Mustang Tech
Plenum spacers?
  • Thread starter Thread starter fastangboi
  • Start date Start date Sep 12, 2006
fastangboi
My first set of nuts vibrated themselves off.
Jul 26, 2006
274
Slowville
Sep 12, 2006
  • Sep 12, 2006
Any body running these? are they just a gimic or are they worth a few more horses?
DropTopPony
Noob Slayer
2,570
south jersey
Sep 13, 2006
  • Sep 13, 2006
Since you have a P&P'd stock plenum you will benefit from one. Steeda makes the nicest one.
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Sep 13, 2006
  • Sep 13, 2006
I had one with my stock Tb/plenum.. didn't do ****, waste of 60 bucks imo
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Sep 13, 2006
  • Sep 13, 2006
It will help out, but nothing noticable.
BooWFO
991
Louisville, KY
Sep 13, 2006
  • Sep 13, 2006
You know I was debating picking one up and porting it like I did the upper plenum. It seems most of the aftermarket plenums are taller. Perhaps that is where some of the STP feel of a plenum swap comes from. The increased "runner" length.
RedDaemon
3,470
9
108
Atlanta, GA
Sep 13, 2006
  • Sep 13, 2006
do u wanna p & p my plenum?
sgarlic
3,085
Sep 13, 2006
  • Sep 13, 2006
I say go for it. In the long run, it might contribute to an extra couple horsies after you've got a bunch of other supporting mods. I'm a believer in "every little bit helps" .... if you've got the cash to spend on it.
fastangboi
Jul 26, 2006
274
Slowville
Sep 13, 2006
  • Sep 13, 2006
It really is a teadious task to do p/p yourself. my only warning to those thinking of doing the same is that the Non PI and PI uppers are slightly different.
PI has a 90degree angle for throttlebody mounting while Non is slightly angled down.
NonPI has less volume to begin with. on the bottom there is a small trench that goes from the throttle body to the inlet. Actual diameteris barely smaller but then it has that relief at the bottom.
The fitting for the vacuum line on the back is bigger on the PI.
i p/p a 97 plenum for my 00 and i probably only gained a difference from the polish and the lack of casting flash. im thinking of either going with an Acufab 75mm set or just p/p my 00 plenum.
I advise not throwing a nonPI on a PI. you would probably have gains the other way though
04YELLOWGT
1,135
Indiana
Sep 13, 2006
  • Sep 13, 2006
Not worth buying...
fastangboi
Jul 26, 2006
274
Slowville
Sep 14, 2006
#10
  • Sep 14, 2006
  • #10
so the votes are about even. i was thinking it was gimicky like the Tornado you stick in the air tube. the money spent isnt worth the gain
G
Bonnet/ hood running horse.
  • Gary 67
  • Aug 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 3, 2026
DadLife0724
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
M
Hello, from Illinois
  • midstroke
  • Sep 13, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 13, 2026
LILCBRA
