  • SN95 4.6L Mustang Tech
Plugs in an 03 GT
  • Thread starter Thread starter jrc_03_gt
  • Start date Start date Jan 31, 2008
1 of 2 Next Last
jrc_03_gt
786
  • Jan 31, 2008
OK I have done plugs before, but where the heck are they? What do I have to do to get to them? I coud see them on my 2005 grand caravan. I have a 2003 GT.
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Jan 31, 2008
  • Jan 31, 2008
um on the top of the heads where the CoPs are bolted on... just below the fuel rails.
jrc_03_gt
786
  • Jan 31, 2008
i see the pink tops I think those are the injectors I did not notice the plugs though.
myponyrocks
Apr 18, 2004
1,219
Jan 31, 2008
  • Jan 31, 2008
south of the injectors... I'd show you a pic, but my shaker blocks em... there are 4 circle cutouts in the valve covers on the heads....
jrc_03_gt
786
  • Jan 31, 2008
where are the wires??????????????????
04YELLOWGT
1,135
Indiana
Jan 31, 2008
  • Jan 31, 2008
There are no wires.
First pull out your fuel injectors.
Then remove the fuel rails.
From there you will see 4 black "boots" on each side of the motor. These are your COPs. Pull those out to reveal your Spark plugs.
From there blow out each hole to remove any dirt or junk that may have gotten down the hole.
Then your good to remove them.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 31, 2008
  • Jan 31, 2008
no wires. there are coils on top of the plugs. the coils will have little numbers on them, including 12029. the bolts holding down the coils are 7mm. make sure you properly torque the spark plugs.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 31, 2008
  • Jan 31, 2008
04YELLOWGT said:
There are no wires.
fuel rails stay. ive done spark plugs on mod motors a few hundred times and have NEVER pulled a rail or injector.
jrc_03_gt
786
  • Jan 31, 2008
"COPs"
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 31, 2008
#10
  • Jan 31, 2008
  • #10
coil on plug. there is a coil directly over each spark plug.
04YELLOWGT
1,135
Indiana
Jan 31, 2008
#11
  • Jan 31, 2008
  • #11
Fuel injectors your right, don't know why I was thinking that but I always pull the fuel rails because its easier to work with them out of the way.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 31, 2008
#12
  • Jan 31, 2008
  • #12
o, i just take the bolt off and pull. the coils come right out, and i have a 12" long swivel spark plug socket that drops right in there.
jrc_03_gt
786
#13
  • Jan 31, 2008
  • #13
Thanks for the info guys I only have 13k on the stang but some time I will change them.
04YELLOWGT
1,135
Indiana
Jan 31, 2008
#14
  • Jan 31, 2008
  • #14
Maybe I just like being difficult. LOL
It still only takes me about 15-20mins to change them all.
jrc_03_gt
786
#15
  • Feb 1, 2008
  • #15
Are the Bosch platinum 4's a good choice??
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 1, 2008
#16
  • Feb 1, 2008
  • #16
no, get Motorcraft or Autolite. NGK if you wanna feel saucy.
the98stang
2,408
Clovis, CA
Feb 1, 2008
#17
  • Feb 1, 2008
  • #17
o gawd if you don't know where they are you better not do the job....i can see a blown spark plug(s) or stripped heads in your future
M
MichaelsLilGray
32
Tyler, Texas
Feb 1, 2008
#18
  • Feb 1, 2008
  • #18
Thats a little harsh man..
Anyways... you dont have to have the fuel rails removed... the only thing you need is a 10" extention and a deep socket...remove them easy enough.. you can always get to them just dont give up =P there is always a straight shot.. just fyi...
When putting them back in.. hand tighten... if any resistance.. turn counter clockwise till you hear it skip on the tip of the thread and try again... when you get it hand tightened, another 1/8th of a turn with the ratchet secures them without sceasing. Put the coil back over the plug.. you will NOT hear the old CLICK that you use to get with wires... when you have it on HAND TIGHTeN the coil on plug (CoP), then just like the plug, another 1/8th of a turn. DO NOT OVER TIGHTEN!!!! You tighten over 20lb of preasure.. you break the seat on the Intake Manifold.. its not fun replacing one so DONT DO IT PLEASE! Other than that your Done, Resecure the molex connector on your CoP and that cylender is done.
The passenger side of the engine is the hardest part... Air intake must be removed... and the last two you kind of have to fight the heater core return lines... Dont give up though.. break the plug loose and hand loosen..
One more thing.... Plugs arnt pregapped... I dont give a damn who tells you otherwise.. factory "oem" is .040-.042 Your GT requires .052 Please remember to do that.. it does wonders =P Good luck
G
GettinThere
553
Central Texas
Feb 1, 2008
#19
  • Feb 1, 2008
  • #19
In the meantime, get a Haynes manual and read up on it.
MichaelsLilGray said:
Thats a little harsh man...
Maybe it is a little harsh, but I think the98stang is right. Good info btw.
streethorse
1,042
Dallas Texas
Feb 1, 2008
#20
  • Feb 1, 2008
  • #20
You remove the rails, injectors, and change the plugs in 15 minutes.
1 of 2 Next Last
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
