PLX m300 Install to EGR to twEECer (Binary Editor)
Stanger007
2,015
Baton Rouge, LA
Just wanted to post up a quick little note on the PLX m300 Wideband meter.
Did an install of one this weekend and it went great. The PLX m300 is a great meter, it is very easy to install, but not quite as full featured as my LC-1.
The basic hookup is to screw the wideband into a bung on the exhaust, route a cable into the car (we used the shifter hole) and plug into the unit's display. Off the display there is a 12v power and ground, we probed around with a voltmeter to find a couple good wires for this and then we routed the 0-5v output back out the shifter hole and plugged it into the Signal Return wire of the EGR.
On the logging side of things I was using Binary Editor - the voltage was off by about 0.3v by the time the PCM picked it up, so I made a quick adjustment to the transfer curve (It's linear so only two points really needed) and we were off... easy as pie.
This was a temporary install into someone's car to do some WOT tuning. In the future I will probably rig up an O2 harness to let me plug the sensor straight into the exhaust without the need for a bung welded just to do WOT tuning for others that don't have a bung welded for a permanent install.
So there you have it. :nice:
Wes
How did you adjust the voltage using the transfer curve? i have both calcon and BE but ive been using calcon for datalogging. Please be specific about how you adjust the transfer curve. i noticed that my AFR was a little bit higher than it normally is and i want to make sure that what im datalogging is the correct AFR since i run a 150 shot of N2O.
Thanks Bud
larry
I went into my BE transfer, which was 10 = 0 and 20 = 5 and noticed that it was off a bit, so I set 9.7 = 0 and 19.7 = 5 and it was dead on with the gauge.
If you are using CalCon, you will find the transfer file in your STRK directory under "Program Files".
Wes
thanks for the reply Wes. i still dont understand how i will know if the transfer is a little off though. how do you determine that the voltage transfer for the AFR reading is incorrect or correct? Mine might be correct? because im tapped into the EVP return line and its not hooked up to the EGR. Over on Daren Woodalls site he stated that once he unhooked the EVP sensor that his AFR was dead on and was getting the correct voltage transfer. Do you agree?? Thanks again buddy for chiming in on this i really apprieciate it
Big Lar
Just eyeballing the laptop vs the gauge, the two differed slightly -- probably because of a voltage drop between where I grounded the meter (behind the console) and the PCM (in the kickpanel).
When the gauge is turned on and was warming up, it would put out a steady gauge reading and voltage - I saw the difference and got the two to match.
This is really the only area that I *really* like my LC-1 - you can have it output a steady voltage and then measure that voltage by the time it hits the PCM to get the transfer EXACTLY dead on. Adjusting the PLX like this got it close enough for comfort though - I wouldn't hesitate to run it like this on my supercharged car.
Wes
Oh ok wes i get it now thanks again for your responses!!
I reaaly had a hard time just getting the plx 300 to datalog in calcon. Once i figured out that you have to check diywb in datalogging it worked fine DUH. Last nite was the first time i saw my AFR in Calcon so now im getting excited. Do you have any knowledge about N2O using the CBAZA strategy??
Thanks again
larry
