K kiNe5 New Member Oct 26, 2004 18 0 0 Jun 13, 2006 #1 Jun 13, 2006 #1 my mustang dies on me when im just idling for no reason. I have to keep pushing the gas to keep it alive. plz help!
R red95gtconvert New Member May 29, 2006 382 0 0 Ponca city, OK Jun 13, 2006 #2 Jun 13, 2006 #2 Check your Idle air control motor, it might have died on you, that or it may be carboned up. It is located on the the throttle body with a plug in connector and 2 bolts holding it on.
RaceDvr50 New Member Jul 26, 2005 121 0 0 Coon Rapids Jun 13, 2006 #3 Jun 13, 2006 #3 +1 for that, also check what your vacuum is. You might have popped a hose loose, it would have to be a large one though to kill the car.
MysteryMachine Active Member Jun 21, 2003 1,835 2 39 Parkesburg, PA Jun 13, 2006 #4 Jun 13, 2006 #4 Is this a new problem? You could up your idle a little till it stops shutting off if its not the IAC
Blackened302 Active Member Jul 21, 2005 1,439 0 36 South TX Jun 13, 2006 #5 Jun 13, 2006 #5 also pull the codes (advance does a nice job).
