Popping Noise. Need help asap
Could be many things...
Put a jackstand under the body.
Grab the tire that is in the air with both hands and forcefully but carefully see if there is any play in your front wheels in any direction; in/out, left/right, up/down.
Also while it is up visually inspect the suspension components including steering rack bushings and tie rod boots.
Another thing to do while it is up is spray silicone spray all over any exposed bushings you can see such as sway bar end links, a-arm, etc.
