  • SN95 4.6L Mustang Tech
ported heads
  • Thread starter Thread starter westgastang5.0Coyote
  • Start date Start date Oct 14, 2008
192
Temple,Ga
Oct 14, 2008
  • Oct 14, 2008
I know a guy who has some 98gt ported heads. Can you use ported heads for a pi swap? He says the cam is in the heads.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Oct 14, 2008
  • Oct 14, 2008
well there not PI heads, there just ported NPI heads, i am going with ported npi's, and a good ported npi can flow as good as a pi heads, but it will not raise your compression....
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 14, 2008
  • Oct 14, 2008
This is true. "Stage II" and above may actually lower your compression a bit. I'm @ about 10.3:1 instead of 10.5:1 because of combustion chamber porting and CC matching
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 14, 2008
  • Oct 14, 2008
with ported NPI heads you still have a restriction in the intake compared to a PI swap , PI swap would be best , or low mileage junkyard 99-04 engine swap
98COBRA281
1,348
30
59
Oct 14, 2008
  • Oct 14, 2008
yeah i did quite a bit of chamber porting too, ive been watching the days waiting for you get that monster dyno'ed
T
TGJ
1,049
  • Oct 14, 2008
That is resolved by putting a PI Intake on the NPI heads...
98COBRA281
1,348
30
59
Oct 14, 2008
  • Oct 14, 2008
why???, you can port match a npi head to a pi gasket.......
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 14, 2008
  • Oct 14, 2008
He's talking about the intake manifold like the post above.
And it was on the dyno with not horrible results - just a totally impeded climb due messed tune. i hope to dyno this saturday if my tuner can get back to me with a tune by then based off my datalogging data.
98COBRA281
1,348
30
59
Oct 14, 2008
  • Oct 14, 2008
oh... i thought he ment intake port, yeah but i wanna see the best #'s
Green&GoldGT
302
Virginia
Oct 14, 2008
#10
  • Oct 14, 2008
  • #10
Ported NPI's only flow better than ported pi's(in most comparable cases) in very low and high lift. Modular cams spend more time in the mid lift, so you want the heads to flow the best in your cams' range.
Just guessing, ported NPI flow better than Ported PI's above .550" lift. But more than likely your cams dont even lift that high. The Crower camshafts in my car have .581" lift gross, but that doesn't mean I'm going to buy Ported NPI's because they flow better at that high of lift. A cam barely spends any time at the higher lifts, but the cam will have a longer duration at mid lift from both sides of the lobe.
More CFM doesn't always mean more power. Especially considering how sensitive 2v heads are to big ports.
Hope this helps.
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
DangStitches
D
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
