porting e6 heads??
  • Thread starter Thread starter z2o_what
  • Start date Start date May 23, 2005
z2o_what
309
princeton, WV
May 23, 2005
  • May 23, 2005
i have a set of e6 heads lying around and i was wondering if they could be ported and "worked" to flow as good as e7s.
i wouldn't think they could be......but i figured that i would ask to see if anyone knows.
D
Daggar
3,902
  • May 23, 2005
I've heard of some pretty amazing things being done with the e6 heads. I don't have any flow data on ported versions though. Most of the gains were the result of reshaping the cumbustion chambers and unshrouding the valves.
z2o_what
309
princeton, WV
May 23, 2005
  • May 23, 2005
do you know where i could find any info on reshaping the cumbustion chambers and unshrouding the valves?
D
Daggar
3,902
  • May 23, 2005
Your local machine shop would be a good source. You could also do a search for "e6 heads" in your internet search engine. I've come across various articles from time to time. I'll be looking into a little more myself here in the very near future as I plan to remove my heads and swap the stockers back in to prep these for a new combo. The headwork is not something that I could attempt on my own.
z2o_what
309
princeton, WV
May 24, 2005
  • May 24, 2005
none of my local machine shops are doing any "custom" headwork other than 3-angle valve jobs, until thier work slows down
if i were to try unshrouding the intake valves myself.......and if i didn't do it properly would it make my car run worse than stock?........or would it have to be done professionally for the car to run right?
im rebuilding the motor right now......and a friend offered me a $150 and a set of "freshly worked" D80Es for the e7s i was previously running.
So im most likely going back to the e6s and i would like for the car to run pretty good.
M
Mean86GT
46
  • May 24, 2005
theres not much you can do to harm an e6 head, they already suck
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
