POS EGR
8YO_VTEC
63
Burke, Va
Think my EGR is dead. Someone please explain how I can test it. I'm not good at testing stuff for good/bad so please be detailed if you can. Especially on explaining vaccuum and electrical stuff. Thank you :)
It's an '87
how do you know it is bad if you dont know how to test it or the EVP? im not trying to be a jerk, but rather to perhaps get more info about your problems and codes you might have.
the egr inputs spent (inert) gasses at cruise. this cools the chambers and improves fuel economy. while the egr is active, the puter dials in a lot of timing, as the egr gasses dilute the mixture and make it less volatile.
the puter sends a signal to the EVR to activate the EGR valve. at idle pull the vac hose off the egr - note if it has vac - it should not.
there is more with the EVR, but since you mentioned EGR specifically, ill stop (besides Michael, JR, et al explain this stuff much better than i).
as an aside, sometimes simply cleaning the pintle in the EGR helps - it can get coked up and keep the egr slightly open when it should not be. conversely, it might not open as far as it should when it should be open all the way, which could lead to detonation.
good luck.
If you are just trying to test the EGR valve, pull the line off it when the engine is running and put some vaccume to it, you can put a hose on it and use your mouth, that's all it takes, if the engine stalls, it works. If you take the line off and the engine runs better, that means its stuck open.
EGR systems do get clogged and do break, like everything else. What makes you think it is "dead"?
