96 Cobra 4.6 4v, have had a longstanding intermittent issue where I have power issues / cutting out at over 6k rpm. Video of the issue with fuel pressure test: 1st gear, half throttle or LESS pull
View: https://youtu.be/Uji7Ox0ioSI
You may have to turn up the volume to really hear the slight-to-moderate cut outs at 6k-ish or so RPM.
I have either verified, or replaced the following in the last year:
In the last 1 - 2 weeks:
- Fuel pressure OK
- Fuel pump strainer
- Fuel tank entirely pulled and cleaned
- Fuel rails pulled and cleaned
- Fuel pressure regulator
- Fuel filter
- Fuel pump 12v power is solid
- Fuel pump flow test at rails (right around 1 gal from supply line, half a gal from rail at return)
- New injectors (60# with tune) cleaned and flow tested (redneck style)
- Plugs brand new, NGK TR55, gapped at .054" but dropping gap to .035" after tonight.
- Coil packs from Autozone, duralast iirc
- Battery (completely died, replaced)
- MAF (for testing original MAF)
- Air filter
- Tested and verified NO intake leaks
- Found out my rings are RIP lol
- Cam and crank pos sensors replaced
- Custom tuning by well known mustang tuner
In the last 3 - 6 months:
- Alternator, from LMR
- Alternator power wire
- O2 sensors, replaced them with brand new ones the other day to verify their integrity, checked good so put back old.
- Plug wires, motorcraft 8mm
- Dropped k member to replace exhaust manifold gaskets in case of exhaust leaks
- Removed EGR, capped everything off, tuned out
- Aquired Moates Quarterhorse and mounted on ECU
- Walbro 255lph pump
Now that has lead me to digging deeper and I do not know where to turn to for knowledge on ECU related things such as injector driver that I am suspecting next. I recently aquired a uScope that I'm going to check the injectors with during the 6k+ window where break ups happen. I have video proof of fuel pressure being steady during the window, which I am replicating in 1st gear at half throttle or less. (
This issue only happens at heavy load 6k+ RPM and is intermittent. It is not the same pattern every time. After replacing crank + cam sensor, which is purely coincidence, I had a smooth RPM up to redline. The very next one had slight cut outs. Does anyone have any other ideas, and can help educate on the ECU some? Thanks in advance.
- Fuel pressure OK
- Fuel filter
- Air filter
