  • SN95 4.6L Mustang Tech
Possible Misfire?
  • Thread starter Thread starter matt_01_4.6_gt
  • Start date Start date Apr 24, 2015
M
matt_01_4.6_gt
  • Apr 24, 2015
I have an 01 gt that when you get on it, around 3000 rpm it shutters a little bit. It's only done it a couple times now, but it has me wondering. It makes a shuttering, hesitant noise, then takes off again and I'm wondering if I could have a misfire?
94GTCoupe
1,412
92
79
CA
Apr 25, 2015
  • Apr 25, 2015
Pull codes.
M
matt_01_4.6_gt
  • Apr 25, 2015
It didn't throw any codes
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Apr 26, 2015
  • Apr 26, 2015
Start with the easy stuff, Clean MAF, add some Seafoam, Fuel Filter, higher Octane of gas, change gas stations, air filter, Check PVC system, make sure there is not an abundance of blow-by going through the system. Pull the Cold air intake to see if the PVC is functioning. Blow-by fouls a lot of stuff. Pull the plugs.
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
