  • 1994 - 1995 Specific Tech
Power Distribution Box Problems
  • Thread starter Thread starter Koniz
  • Start date Start date Jun 9, 2006
Koniz
137
Geneseo, IL
Jun 9, 2006
  • Jun 9, 2006
This has been a long problem the past 4 months now, but I am having problems with my car wanting to shut off when I move or when I am at a stop for decent amount of time, my voltage is all over the place on the gauge my battery is brand new my alternater is a year old, I have msd and underdrive pulleys in the car I thouht that was problem put the stock alt pulley back on did fix it disconnected the msd didnt fix and last night I went to start the car and no power so I opened the hood played with the wire to power distribution box and every thing worked again this morning I made sure they were tight they were but I had the feeling the connections for the main power and the alternater wire were corroded at the power distribution box and reconnected everything back still had the same problem but one thing I noticed the stud on the power distribution box was loose, I was wondering if I can change the stud on the box I think that might fix the problem, has anyone else did this before?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 9, 2006
  • Jun 9, 2006
you might need to run a new ground from the motor to the chasis
Koniz
137
Geneseo, IL
Jun 9, 2006
  • Jun 9, 2006
I have checked all the grounds they seem to be fine they are not corroded at all and the cable is still soft and new looking
urban96
3,464
Syracuse, NY
Jun 9, 2006
  • Jun 9, 2006
maybe have the alt bench tested, the voltage regulator went on mine after about a year and pepboys replaced it
Koniz
137
Geneseo, IL
Jun 9, 2006
  • Jun 9, 2006
What were your simptoms for the alternater to be bench checked
urban96
3,464
Syracuse, NY
Jun 9, 2006
  • Jun 9, 2006
it was kinda obvious for mine, whenever i would go above 3K RPM volts spiked to 18v... first time it happen was at night as i was getting on the highway, lights got VERY bright and i didnt know wtf happen. after about 3 times (voltage would only stay high for 2-3 seconds then drop to normal as long as i let the revs drop)
brought it back to pepboys with my recipt, walked back out with a new alt
Koniz
137
Geneseo, IL
Jun 11, 2006
  • Jun 11, 2006
Oh ok, thanks for the post I know my voltage regulater is still good, I doesnt go past 14v I am going to recheck wires and replace the ground and alt wire and maybe the starter wire
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
