power or rac steering
  • Thread starter Thread starter 4ford
  • Start date Start date Jan 4, 2012
4ford
  • Jan 4, 2012
hi i have a 1966 mustang v8 5speed with z bar try y headers and would like power steering. or rack and pinion what do you guys think and do you know if one will fit?
thanks
gikort
82
Jan 4, 2012
  • Jan 4, 2012
In my opinion the factory power steering is horrible. I don't have any experience with the rack and pinion setups, other than they are really expensive. Look into a Borgeson integrated power steering box. Sweet modern setup that bolts right up. I built a DIY junkyard version that was around 200 dollars and works great! Here is the link http://forums.vintage-mustang.com/m...-integrated-power-steering-write-up-pics.html
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Jan 4, 2012
  • Jan 4, 2012
Really awesome work gikort!!
4ford
  • Jan 7, 2012
Talked to the guys @ Borgeson and they said it would fit but i need to get there z bar. It looks better. the systom is about $800.00 with out the pump. he will send me a book and more info on it.. thanks for your info it helps
gikort
82
Jan 7, 2012
  • Jan 7, 2012
Yeah, the hoses will interfere with the factory zbar from what I hear. I run the cable set up for my clutch. I used the stock mustang pump and it works just fine. If you get the box from Borgeson, you can build your own hoses for a LOT cheaper than they sell them. Find a used stock pump that will bolt right up and you should be good to go. Good Luck.
4ford
  • Jan 7, 2012
i have the old pump from the old steering so that should work well is there differnt fittings on the box?
D
Power steering to rack and pinion bolt
  • Demigxd
  • May 21, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 21, 2026
Demigxd
D
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
