Power steering belt
  • Thread starter Thread starter xero0620
  • Start date Start date Aug 16, 2008
xero0620
60
Vacaville Ca.
Aug 16, 2008
  • Aug 16, 2008
How do I figure out what belt to get for my power steering if my engine is an 85 302 but its in a 68 mustang?
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 16, 2008
  • Aug 16, 2008
I don't think it would matter what year the motor is. All Ford small blocks (excluding the 351's) from the 221, right up to the last pushrod 5.0 are the same size. The thing you need to know is the year of the belt drive you're using. If it's a '68 v-belt and '68 pulleys, then you need a belt for a '68.
xero0620
60
Vacaville Ca.
Aug 16, 2008
  • Aug 16, 2008
It is a v belt but how do I know what year my setup is?
xero0620
60
Vacaville Ca.
Aug 16, 2008
  • Aug 16, 2008
The pulley layout goes from the power steering pump, over to the fan, down to the crank and back up to the power steering. The other belt goes from the alternator to the fan, down to the crank and back to the alt. There are no other pulleys or guides that the belt goes over or touches.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Aug 17, 2008
  • Aug 17, 2008
It doesn't matter. All you do is take a piece of string, run it around the pulleys the way the belt would be routed, measure the length, and add about an inch to compensate for the deeper seating of the string in the pulleys versus an actual v-belt. Then you go to a parts store and get a universal v-belt in that length.
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 17, 2008
  • Aug 17, 2008
All mid-to-late '60's small block Ford's used the same power steering setup, regardless of application. Some used different pumps, but all used the same bracket, so your chances of getting the wrong one are slim, assuming you tell them it's a (fill in the year) Mustang.
xero0620
60
Vacaville Ca.
Aug 17, 2008
  • Aug 17, 2008
Replaced the belt today and not only did the squeal stop but I can honestly say the car steers a lot better. Not saying that it drives great or even good but it is noticeably better and reduced the dead feel when driving down the road.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
