Power Steering Issues?Need Advice.
rabidscoobie
616
12
48
College Station,TX
The other day when I started it up and was backing out od the driveway my power steering was whinning cause it was almost empty on fluid,so I filled it up and solved the problem then checked a couple days later and the level had dropped just enough to see it.
So I got under it and started looking at the fittings to see if it was leaking from there and they were all dry that I could see,but I noticed that where the tie rods connect to the steering...where the black rubber boots are they where covered in fluid as if thats where a leak is but I was unable to pinpoint it.
So anyone know whats wrong or what needs to be replaced?Im just wondering since I only get paid on the 3rd of every month,so I cant take it in for the warranty until then.....damn deductables.
this is same thing happent to me, its leaking on passenger side tie rods black rubber boots ? I use lucas power steering leak fix and it fix the problem, 2 month it havent leak yet.
