Power steering leak
  • Thread starter Thread starter my66coupe
  • Start date Start date Jan 18, 2004
M
my66coupe
1,134
Arizona fountain hills
Jan 18, 2004
  • Jan 18, 2004
The front seal on my power steering pump is leaking, How do i go about replacing it? Also, the cap on the pump says only fill with automatic tranny fluid, I have been putting in regular power steering fluid, what should I be using? Thanks alot guys
Mike
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 18, 2004
  • Jan 18, 2004
I have never replaced the seal, I just bought a rebuilt pump, much quicker, and wasnt real expensive. ATF and power steering fluid are one in the same.
crushnut
870
Oregon
Jan 18, 2004
  • Jan 18, 2004
Use type F ATF or PSF, its your choice to which one.
M
my66coupe
1,134
Jan 19, 2004
  • Jan 19, 2004
Anyone know how i go about removing the front cover and replacing the seal?
Mike
C
C0V3R
524
Australia
Jan 19, 2004
  • Jan 19, 2004
Mike
If its like the 68, all you have to do is undo the nut at the back and it pretty much pulls apart.
golf4283
1,253
Orland Park, Illinois
Jan 19, 2004
  • Jan 19, 2004
The life of the seals will depend on which fluid you use. If it says to use ATF, then use ATF. Just dont mix the two.
M
my66coupe
1,134
Jan 19, 2004
  • Jan 19, 2004
alright cool, ill attack that project next weekend. I already have mixed the 2 fluids, How do I completely drain the fluid out of everything and start fresh?
Mike
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
H
Steering whine
  • healy1963
  • May 9, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 10, 2026
gkomo
F
Power Steering Pump
  • Fri Guy
  • Apr 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 29, 2026
Fri Guy
F
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 7:51 AM
AlexM556
A
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
