Power steering ok to run without pump??????
It won't hurt anything but it will be difficult to steer because you have to push the fluid throught the system manually, not just push the wheels side to side manually. Also that fluid is probally going to end up overflowing out of the resivour. You'll probally also get air in the lines which isn't a big deal but just thought I would throw that in there anyways.
The pump wont be on the car, for maybe a week at most. Unless NAPA has a P/S pulley which i will check tomarrow.
I've heard differently - that the fox mustang uses power-assist steering, not power-steering and that you can run it without fluid at all, just plug it up.
