Power steering pulley HELPP!!!!
  • Thread starter Thread starter btsclan
  • Start date Start date Jun 5, 2008
btsclan
64
Seattle, WA
Jun 5, 2008
  • Jun 5, 2008
This is driving me crazy, I bought an a/c delete kit and I rented a pulley removal kit for my p/s. There is a hex screw in the middle of the pulley, I cant get it out nor in my research have seen anyone mention anything about this hex bolt, some say all you need to do is pull the pulley off but it would seem that you need to get that bolt out first? What do I do, do I need to get that out or is the pulley just pressed on? Please help this is driving me crazy.
The hex or allen wrench bolt is right in the middle of the pulley,
PLEASE HELP
Thank you
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 5, 2008
  • Jun 5, 2008
The power steering pump pulley presses on. Don't worry about that middle hex. It's not a bolt, that is the middle of the pumps shaft. Install the tool how it says in the directions, then use an impact to pull it off. It is very simple. You reinstall it the same way, just reverse the steps.
68converted
772
Colorado
Jun 5, 2008
  • Jun 5, 2008
PLEASE HELP
Thank you
I just went through this. Slip the two half clamps over the pully end, screw in the center bolt. There are threads inside the shaft. LOL
Do the reverse to put it back on. I used a little trick of heating up the pully before I put it on, virtually slipped right on. When it cools, it shrinks and will not move until it is pulled again.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 5, 2008
  • Jun 5, 2008
You will need to rent or buy a PS steering puller. The PS pulley has a ridge that the puller seats on. Then you crank the screw on the middle of the puller to get the pulley off the shaft.
You can rent the tool at Autozone or other auto parts stores.
I have used a bearing separator & harmonic balancer puller together to do the job.
Use this tool to put it back on...
I usually just use the bolt that comes with the new PS pump.
Brandon11010
71
  • Jun 6, 2008
i just tried using a 2 jaw puller... bad idea...bent the pully all to **** and it didnt move a bit on the shaft...grrr
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 6, 2008
  • Jun 6, 2008
Why exactly are you removing the PS pulley? The AC delete kit should just require moving the power steering pump assembly up higher on the head using the new bracket. This is what vehicles without AC had in the first place. Its been a while since I did this to mine, but I don't remember ever having to remove the PS pulley.
btsclan
64
Seattle, WA
Jun 6, 2008
  • Jun 6, 2008
I bought the a/c delete kit from ford racing, I actually have the delete kit in there and the p/s moved up however, I need to take the pulley off to get to the p/s bolts, Since the p/s is brought up higher the angle needs to be changed. Basicly the p/s pump it self needs to be rotated on the main p/s braket. It is kinking one of the hoses with the way it is now and the resivour is almost verital and almost hiting the hood.
btsclan
64
Seattle, WA
Jun 6, 2008
  • Jun 6, 2008
How do you thread the installer in the pump shaft since its not threaded. That hex bolt that I thought was a bolt isnt a bolt, the end of the pump shaft just has a spot for an allen wrench. I looked at a new unit at my local auto shop and the shaft is not threaded, so how do I re-install the pulley??
mustangfan1990
505
Lenoir, North Carolina
Jun 6, 2008
  • Jun 6, 2008
Wow I never had this problem hmmmmmmm
mustangfan1990
505
Jun 6, 2008
#10
  • Jun 6, 2008
  • #10
btsclan
64
Seattle, WA
Jun 6, 2008
#11
  • Jun 6, 2008
  • #11
I've got an 87gt with an auto tranny, I've heard that later years with manual have a different size pump, what delete kit did you use?
mustangfan1990
505
Jun 6, 2008
#12
  • Jun 6, 2008
  • #12
The ford racing one...the one i used is just a alluminum bracket the the power steering bolts too and it has a bracket that bolts to the front side of the pump to the water pump and such for support...also my car is a 90 GT but the car was auto when it was stock I converted it
9
90bluecoupe
76
Abingdon md
Jun 6, 2008
#13
  • Jun 6, 2008
  • #13
I've done 7 ac delete kits and not one time did i ever remove the p/s pulley, I dont get it.
wildstang90
87
Bristol, TN
Jun 6, 2008
#14
  • Jun 6, 2008
  • #14
I put in the ford racing kit today to move the pump where the AC unit was I had no problems at all. Only other thing I did that you might need to do is rerout the line that runs to the pump easy fix. I do know if you are looking at the drawing for the install it looks like you have to pull the pulley off but you dont.
68converted
772
Colorado
Jun 6, 2008
#15
  • Jun 6, 2008
  • #15
Inside the shaft, it is threaded. Mine was filled up with garbage, but a little carb cleaner sprayed it out.
dollarbill
140
Decatur, IL
Aug 25, 2010
#16
  • Aug 25, 2010
  • #16
I'm having trouble installing the frpp a/c delete kit on my 89. I can't get the power steering unit off of the long stud in the right side of the head. The stud won't screw out so I can put the new stuff on. I have searched on several sites and nobody has mentioned this problem. It is the far right bolt that goes through the big a/c bracket, but its a stud with a nut not a bolt and I can't figure out how to get it out.
L
Lawbreaker5.0
543
Texas
Aug 25, 2010
#17
  • Aug 25, 2010
  • #17
The stud should spin out. It's prob frozen and needs some TLC. Maybe some PB blaster and a good pair of vice grips. I always left the stud in the head and pulled the radiator. That should give you enough room to pull the pump off the stud.
dollarbill
140
Decatur, IL
Aug 26, 2010
#18
  • Aug 26, 2010
  • #18
I sprayed it down with Marvel Mystery Oil yesterday, and borrowed a decent pair of Vise Grips from work. It came right out, job is complete. My car already had the condenser and evaporator and all the lines and stuff stripped so I maybe lost another 10-15 lbs and cleaned up the engine bay a bit. Thanks for the tip...
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
