power steering pump too hot
  • Thread starter Thread starter e7gt
  • Start date Start date Jun 11, 2008
E
e7gt
  • Jun 11, 2008
I am installing power steering on a 68 Mustang convertible, the car did not come from the factory with PS, I have installed everything on the car that it requires for PS. The PS pump & fluid is way too hot. I have replaced the pumps with 3 different pumps & replaced the control valve, also 3 times. The lines are clean & not crossed. Compared to another 68, everything the same. I don't understand why it is overheating?
BarnStang
1,260
Hagerstown, MD
Jun 11, 2008
  • Jun 11, 2008
How are you determining that it's too hot? P/S does run pretty hot when th car is fully warmed up. Is the pump locing up? Hoses melting? SLave cyl seizing? WHat's going on with it?
E
e7gt
  • Jun 11, 2008
The fluid is so hot it melted my plastic funnel, the housing of the pump you cannot touch. Also, can't touch control valve, too hot.
G
gjz30075
250
Roswell, Ga
Jun 12, 2008
  • Jun 12, 2008
Make sure you're using Type F fluid. I wasn't and found my pump very hot, also.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Jun 14, 2008
  • Jun 14, 2008
Sounds like your turning the pump to fast, check the pulley sizes.
I disagree with the type F fluid, I run the Trick-shift trany fluid in my 65 power steering and it works great and stays cool. I also run this fluid in my C4 trany and Im running a supercharger with NOS.
Dont get caught up with what the factory recommends, there is better stuff out there.
P.S...... You changed the factory recommended carb and intake didnt you!
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 17, 2008
  • Jun 17, 2008
Checking the pully size is a good way to go. Maybe switching to a larger pully will help by slowing the fluid down. Does your pressure line have a restrictor in it ? I think there is supposed to be a restrictor in the pressure line.
Also, there are power steering coolers available. They are basically trans coolers.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
F
Power Steering Pump
  • Fri Guy
  • Apr 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 29, 2026
Fri Guy
F
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
