well i looked around, and this is what seams to be the answer: The pump CAN be used, but its recommended that you run an 8cyl one, the 4cyl lines WILL work, but you sacrifice the power steering cooler line. The rack is sketchy, i believe you can get away with the 4 cyl one, but like the pump it is highly recommended that you run the v8 one.
