Power Steering Went Out!
  • Thread starter Thread starter 86StangLX
  • Start date Start date Nov 12, 2004
86StangLX
52
  • Nov 12, 2004
Hey guys,
My power steering has been working fine lately. But when I went to start my car this afternoon, the power steering was totally gone. I checked the fluid level and it's fine, I don't see any leaks or anything like that. I have no idea. Could the pump have just gone out like that? With no warning? Thanks for your help.
-Paul
P
PonyBoy90
555
Toronto
Nov 12, 2004
  • Nov 12, 2004
Yeah, it's possible for your pump to just give up like that.
Usually if you have a leak, you can prolong fixing the problem as long as you keep topping up the reservior, maybe even help it with some Valvoline Max Life with stop leak.
But with your situation, no fluids getting pumped into the rack to assist with the steering.
If you start your engine and turn the steering wheel to the left or right you should hear a sound coming from the pump if it's working. If it's silent, your pumps out.
86StangLX
52
  • Nov 12, 2004
Thanks for your help PonyBoy. I'm thinking it's gone. Just glad it went out in my driveway. Any other ways to check to see if it's functioning?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Nov 12, 2004
  • Nov 12, 2004
I bet it is the rack. Does the pump make a lot of noise???
86StangLX
52
  • Nov 13, 2004
No, the pump isn't making any noise. With the car running, I pulled off the cap and looked at the fluid and it was totally stagnent. No bubbles or movement whatsoever. This leads me to believe there is no circulation happening.
HISSIN50
34
129
Nov 13, 2004
  • Nov 13, 2004
so your power assist went away?
is the pulley turning (or frozen with the belt slipping over it)?
86StangLX
52
  • Nov 13, 2004
The pulley is turning. And yes, my power assist went totally away.
86StangLX
52
  • Nov 13, 2004
Okay, I pulled the hoses off the pump, and started turning the pulley by hand. When I did that, fluid started coming out of the pump, which leads me to believe that the pump is working, but the rack went out. Just looking for second opinions. Any ideas?
90mustangGT
2,773
17
89
Dallas, GA
Nov 13, 2004
  • Nov 13, 2004
The fluid will look stagnet in the resivour, but if you take some out down into the actual pump it will be another story. If the rack goes out, either the valves are frozen shut or the rack seals went out so the fluid is just bypassing.
86StangLX
52
#10
  • Nov 13, 2004
  • #10
Thanks--so does that mean I need to replace the entire rack? I'm quite unfamiliar with this portion of the car. Does the rack go out suddenly like that? It just seems odd. Thanks again!
F
Power Steering Pump
  • Fri Guy
  • Apr 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 29, 2026
Fri Guy
F
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
