power steering
  • Thread starter Thread starter oneturboneeded
  • Start date Start date Aug 31, 2008
O
oneturboneeded
28
  • Aug 31, 2008
will a newer pump bolt up to the old lines?? would it work?
stanger53
89
San Antonio, Texas
Sep 2, 2008
  • Sep 2, 2008
Well, you don't give much information to go on.
I assume you have a Ford-Thompson style pump setup, which was the main pump used from 1965 to 1977.
If you are asking if the later Ford C-II pump, made from 1978 to about 2001, will work - yes, it will. It has the same bolt pattern on the front, so it can fit the earlier style mounting brackets, but you may have to space the housing a bit or trim the bracket to clear the fins on the front of the aluminum pump housing.
The pressure hoses from the earlier cars won't fit the pump, though. The C-II fitting is a swiveling style, so you will have to modify your old hose with a different fitting to make it work.
O
other_shoe
313
  • Sep 2, 2008
What would the advantages of going to the C-II be?
stanger53
89
San Antonio, Texas
Sep 2, 2008
  • Sep 2, 2008
No real advantage that I can see, other than the pumps are not as old, so there are more of them out there. They are a smaller pump, so that may give you some advantage around some accessories.
They are basicaaly like the earlier pumps in design, just with a smaller plastic housing and a swivel pressure fitting.
67rcks
373
Sep 3, 2008
  • Sep 3, 2008
Can you run the P/S pump with no load no fluid without risking its damage? Got new engine and have no use for it (manual steering) but want to keep it prepared for r&p hookup.
O
other_shoe
313
  • Sep 3, 2008
Others here have more expertise, but I'm pretty sure that will damage the pump and fast.
I have a screwy belt set up where the pump is the only thing driven by its belt, so I'd just bypass it. If yours is part of a triangle you'll need a different size. With measuring tape and the old belt you can get one in about five minutes from the local parts house.
yeloxr7
429
  • Sep 3, 2008
One advantage to the plastic-bodied C-II pump is that it's easier to fill properly without making a mess.
dbfarr
191
Boise ID
Nov 8, 2008
  • Nov 8, 2008
What about standard pulleys, can they be pressed on? Or do any of these pumps come with a pulley?
bnickel
5,640
lubbock, texas
Nov 13, 2008
  • Nov 13, 2008
yes the early pulleys can pressed onto the C-II pump so you can keep your v-belt setup. i also don't see any real advantage to using this pump in place of the earlier pumps in fact they are generally quite a bit noisier than the early pump.
if you are converting to rack and pinion then you might want to consider a GM saginaw style pump from a late 70's bronco or mustang II some big fords had them too.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
D
Power steering to rack and pinion bolt
  • Demigxd
  • May 21, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 21, 2026
Demigxd
D
F
Power Steering Pump
  • Fri Guy
  • Apr 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 29, 2026
Fri Guy
F
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
