  • 1994 - 1995 Specific Tech
POWER STEERING
  • Thread starter Thread starter UTGAMER
  • Start date Start date Aug 20, 2010
UTGAMER
215
Dalton, GA
Aug 20, 2010
  • Aug 20, 2010
Well yall finally get everything back in and running right except now my damn steering feels like .......Well kinda like a go -kart. My Power Steering Pressure Hose is leaking fluid pretty rapidly . It will empty over night I was wondering if this is what may be the cause?? it seems like WHILE there is fluid it would steer normal until it lost the fluid?Or unless its bc of pressure loss?? I dunno.. ALSO the steering arm is hitting my dipstick tube . could anyone tell me maybe how the dipstick tube should be routed ? Like which header pipe the dipstick tube bracket should be on and if it would be routed a certain way to clear steering arm ? TIA
UTGAMER
215
Dalton, GA
Aug 20, 2010
  • Aug 20, 2010
And how hard is it to replace the Power Steering Pressure Hose for a beginner like me?
Adam95GT
2,564
Burlington, NJ
Aug 20, 2010
  • Aug 20, 2010
They shouldn't be too bad. Its just a knuckle basher. You might have to slide the rack forward a bit im not 2 sure. The answer is yes low fluid can cause problems
UTGAMER
215
Dalton, GA
Aug 21, 2010
  • Aug 21, 2010
What do you mean slide rack forward? And anyone know about the dipstick hitting the steering arm
ProKiller
3,064
15
78
PA
Aug 21, 2010
  • Aug 21, 2010
the rack and pinion needs to come forward so you have enough room to replace the line. might be easier to unbolt the whole thing to get to the lines.
route the dipstick where ever it doesn't hit the steering column.
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
