Hello everyone, I have had the totally original idea to coyote swap my 1995 mustang gt vert, but I know it takes alot of money and different parts. Ive assembled a basic list of what I think is necessary for the swap(except a Radiator idk if i need somethingspecial of if i can run stock), list is as follows:
Tremec T56 Magnum Transmission 2.66
McLeod T56 Bellhousing
Mustang SVE T56 Conversion Driveshaft - T56 Magnum - 31 Spline
Mustang McLeod RXT Twin Disc Clutch - w/ Aluminum Flywheel - 26 Spline
Coyote PNP Harness & MS3Pro EVO+ HC Package
PBH Coyote Swap Hydroboost Line kit
w/ Coyote Swap Power Steering Pump Reservoir Bracket
GM Type II Power Steering Pump and Pulley
1999-04 Mustang Hydroboost Power Brake Booster
Power By The Hour Coyote Engine Swap Accessory Bracket Kit
Power By The Hour Coyote Swap Fuel System for 1983-97 Mustang
Mustang SVE Coyote Swap Radiator Hose Kit
Mustang BBK Coyote Swap Headers - Ceramic Coated
1979-95 Mustang Maximum Motorsports Engine Swap K-Member Modular/Coyote
1979-04 Mustang Maximum Motorsports Solid Rack Bushings
1994-04 Mustang Maximum Motorsports Non-Offset Front Control Arms
1979-98 Mustang Maximum Motorsports Extreme Duty Adjustable Rear Lower Control Arm Kit w/ Sway Bar Mount
1979-04 Mustang Moroso Coyote Swap Oil Pan 5.0L
Tell me what I should add, remove, or change. Thanks in advance!
