  • SN95 4.6L Mustang Tech
Power wire install
  • Thread starter Thread starter DocG
  • Start date Start date Dec 2, 2005
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Dec 2, 2005
  • Dec 2, 2005
I've tried searching and didn't find anything specific. But...can anyone tell me a good spot to put a amp power line through the firewall on my 04GT. Usually I drill a hole through the plate covering the factory cut-out for a clutch pedal...but since I now have a stick...this won't work. I'd rather not drill another hole in the firewall if I don't have to. So I thought I'd see what other people have done, so I can learn from your mistakes instead of my own.
Pictures are always welcome. Thanks!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 2, 2005
  • Dec 2, 2005
There's a big rubber grommet plug above and to the left of the powerboost in the firewall for this exact purpose.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Dec 2, 2005
  • Dec 2, 2005
Serious...well not that there's a plug there...but that its for this exact purpose?
Big enough for a decent size power wire...maybe 4 gauge?
BooWFO
991
Louisville, KY
Dec 2, 2005
  • Dec 2, 2005
There is also a grommet on the passenger side hidden behind some things it is almost impossible to get to from inside the car too the blower box is between the firewall and the compartment but with a lil work you can get it out and get stuff through there. like I don't know maybe a nitrous line and an amp power wire.
BTW it is much eaiser to push it through from engine bay and the carpet padding is in the way but a quick x on the padding a viola.
2002GreyGT
481
Raleigh, NC
Dec 2, 2005
  • Dec 2, 2005
I fit my 0 Gauge through the above gromet on the drivers side. Was not easy, but worked.
I forget if I fed it from the inside out or vice-versa.
I think I stuck a screwdriver through the hole, and fed the wire from the inside out.
~K
W
WillDuhhBeast
339
Jacksonville Florida
Dec 2, 2005
  • Dec 2, 2005
~K
I dont mean to make this sound so offensive.. but what are you running "0" gauge wire to? It doesn't appear that you have anything that requires such a huge wire..?
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Dec 2, 2005
  • Dec 2, 2005
Wowsa's thats a big wire.
Thanks for the info guys...gonna drop my system in as soon as I can get another amp wire kit (might as well leave it in my other car just in case it gets another system...and for 50 bucks I'd rather buy a new one than take apart the interior just to take out wires!).
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Dec 7, 2005
  • Dec 7, 2005
Not to beat a dead horse here, but from what I saw in my car based on what the suggestions were....one grommet (nothing passing through) on passenger side, looked to be behind the A/C cylinder? The other is a big fat grommet with things already passing through it. Looked like it would be easier to just use the passenger side one.
So...passenger side one, did you guys just poke a hole in it, then pass your wire through? Does this stay sealed well enough? Did you just route your power wire along the firewall trim and around the back, or did you go straight to the front of the car, then over?
For the other grommet, do you just pull the grommet off, or try to route the power wire through along with the other wires already going through, looks pretty tight on this spot.
Any engine bay pics?
My new headunit and amp kit comes tomorrow and its supposed to snow here, so I'm thinking snowday and no work on Friday...which means I'll be busy on the car. But I like to be ready so I don't hit a snag and have to come back inside and ask the Stangnet crew!
Thanks!
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
'67-68 Scott Drake Trap Door w/6x9 Speaker Pods
  • bchampion
  • Jun 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 16, 2025
bchampion
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
