PowerMaster Mastertorque Starter Install?
  • Thread starter Thread starter soontobefastfox
  • Start date Start date May 28, 2007
soontobefastfox
275
Troy, Michigan
May 28, 2007
  • May 28, 2007
Does anyone have experience installing one of these? I have installed but I am a little confused from the directions. Since the stock 5.0 only has 1 wire that connects to the starter the instructions say to jump it from the BAT terminal of the starter.
So I am a correct to create a wire that connects the ignition side terminal of the starter to the BAT terminal of the starter?
M
mattsclean90
17
  • May 28, 2007
Yes all you have to do is make a jumper wire. Just make sure you use a good quality wire.
soontobefastfox
275
Troy, Michigan
May 29, 2007
  • May 29, 2007
Thanks, thats whatI thought, I also looked online at PowerMaster's website and they had a newer version of the instructions you could download and had a diagram and clearer instructions.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 29, 2007
  • May 29, 2007
I had the same problem when I installed one. The jumper wire made it work.
vikingpower
656
CWU Ellensburg, WA
May 29, 2007
  • May 29, 2007
They should've included that wire, I hate having to fabricate stuff
soontobefastfox
275
Troy, Michigan
May 29, 2007
  • May 29, 2007
Great! So you have a powermasters starter? I have a question for you the battery cable did you need to make the hole bigger so it could fit on the post? Cause that is what I am going to have to do.
They should have but it was a simple fab. Took about 3" of 10 AWG wire and put the crimpled the correct sized eyelets on it and was ready to go. Not bad could be way worse, wiring up a kill switch for a battery relocation kit, that took awhile!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 29, 2007
  • May 29, 2007
I did the battery relocate at the same time as the starter. I;m actually not sure what eyelet I used so it would fit. sorry mate. If I hae time tomorrow I will look on the car.
soontobefastfox
275
Troy, Michigan
May 30, 2007
  • May 30, 2007
I'm not talking about the jumper wire, I am talking about the stock wiring to the starter, it will not fit on the BAT terminal.
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
