  • SN95 4.6L Mustang Tech
Predator
  • Thread starter Thread starter Ruckus46Gt
  • Start date Start date Apr 22, 2004
Ruckus46Gt
385
Long Island
Apr 22, 2004
  • Apr 22, 2004
How does everyone like there predator that got one? I just got mine and put the tune in. Anyone mess with the adjustments yet? Anyone notice any gains? I mean it felt a little different but mainly on how it sounded and felt when i got on it.
Ruckus46Gt
385
Long Island
Apr 22, 2004
  • Apr 22, 2004
oh yea does anyone know what the timing is or if there is a way to tell. I called diablo and they said they can not give that information out
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Apr 22, 2004
  • Apr 22, 2004
Stock ignition timing should be 10 degrees.
Ruckus46Gt
385
Long Island
Apr 22, 2004
  • Apr 22, 2004
yea stock is 10 but the diablo tune sets it to something and then from the tune you can advance it 10 more percent from what diablo says
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Apr 22, 2004
  • Apr 22, 2004
It doesnt give it to you in degrees ?
Ruckus46Gt
385
Long Island
Apr 22, 2004
  • Apr 22, 2004
nope
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Apr 23, 2004
  • Apr 23, 2004
Damn. That sucks.
scottgb
Pasadena, MD
Apr 23, 2004
  • Apr 23, 2004
Just ordered mine today. It says 'in stock', so hopefully I'll get it some time next week. I was really glad to see it does in fact work with the 2004 (was getting worried there for a while). I'm looking forward to the automatic trans adjustments more than anything.
It would have been nice if they could have made it set the traction lock off by default (I think I read the Hypertech does that), but that's a minor thing.
XTONKAX
619
UT
Apr 23, 2004
  • Apr 23, 2004
It's green. Sitting here at work with me. Mocking me. Daring me to go home early. I've got to remember how to reconnect the speedometer after I pull the SpeedCal now...
sl0stang
#10
  • Apr 23, 2004
  • #10
It would have been nice if they could have made it set the traction lock off by default (I think I read the Hypertech does that) said:
I thought it does disable the traction control ? I just was reading on a forum somewhere that it does disable it.. Hmm, that was pretty much my reason for buying one.
Ruckus46Gt
385
Long Island
Apr 23, 2004
#11
  • Apr 23, 2004
  • #11
it does its under modifiy tune and under the axle section for some reason(axle gears, tires by rev, and traction under this section)
YardSpecial
2,664
MT
Apr 23, 2004
#12
  • Apr 23, 2004
  • #12
Here is what the box does:
The Mustang Predator allows the end user to adjust the following parameters:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
Shift Pressure
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
So it DOES shut the TC off !!
01mgvert
302
#13
  • Apr 23, 2004
  • #13
I e-mailed Diablo a question about timing. In their reply, they were careful not to give away their "secret recipe," but they did mentioned that their performance tune advances timing anywhere from 2-6 degrees. I used the diagnostic component of the Predator ("Real Time Streaming") and my idle timing is set at 14 degrees. I wish that the Predator come with more detailed instructions because a lot of diagnostic information was provided, and I have no idea what it means.
They also noted that the air/fuel scale is leaned out by one point.
DELOS02GT
461
Naperville, IL
Apr 23, 2004
#14
  • Apr 23, 2004
  • #14
On another web site that I visit there is a guy on ther that has the Diablo. He had the car dynoed today and guess what his gain was......5HP. That's it....5HP. Does that sound right? Did you notice more of a gain than that?!
scottgb
Pasadena, MD
Apr 25, 2004
#15
  • Apr 25, 2004
  • #15
Nice! I completely missed that bit about traction being off, when I looked over the specs... ooops. That's definitely a bonus then.
Turbo92PGT
746
Auburn Washington
Apr 25, 2004
#16
  • Apr 25, 2004
  • #16
I want to get a tuner, because then i can pull the codes when my car throws one. I was thinking the predator, but do they even make one for the 98's? I read somewhere its 99- present. What should I get for my 98?? It's gotta be a tuner though, because I wanna pull codes.
XTONKAX
619
UT
Apr 25, 2004
#17
  • Apr 25, 2004
  • #17
I opted to set the traction to off on the tune. It's most assuredly off. I was hoping it would just be set to off by default, and that I could turn it on with the button, but that's not the case. Oh well.
Took out my SpeedCal, and the tuner seems to have done a good job with the recalibration. I'm pleased.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Apr 25, 2004
#18
  • Apr 25, 2004
  • #18
that sounds about right. the stock program isn't bad for stock or near stock. unless you have some major mods, you aren't going to pick up a whole lot by a tune. Diablo's claim of 25rwhp is
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
