Ok, there are four major types of primer out there (then for 3 of them low build, medium build, or high build variations):
1) Spray Can Primer- Should not be used except to protect a surface in high humidity for a day or two at the max.
2) Primer Etcher- This is sprayed on clean bare metal only
3) Primer Sealer- This is sprayed on top of smoothed (very lighly sanded) primer etcher. This is what actually protects and seals the metal from rusting. A Tip is to substitute one part of the primer sealer for one part of your base color (unless you have black primer sealer). This way if you get a chip in the paint, the primer sealer is tinted the color of the car and won't show as much.
4) All in One system- This primer sealer can be sprayed directly onto bare metal and protects the metal from rusting.
As to the low/medium/high build aspect. For most of the car you'll go with the low build. If you have a lot of scratch marks from sanding or stripping the car, go with the medium build. If you weren't stripping the car totally, and had orangpeel, small pinholes, or large scratched, use either the medium primer for most of the car and the high build primer for the bad areas. Then sand, sand, sand (of course)!
As for cleaning the metal, get many, many tack cloths. Also get a gallon of silicon & wax remover such as SuperKlean or some other substitute. Using a regular terry cloth towel and or compressed air, blow out all crevices of the car and then the main panel. Wet the ground thoroughly all around the area you’re primering (till it’s muddy), this keeps the dust from being kicked up.
Then wipe down the car using paper towels and the SuperKlean (with clean nitrile or rubber gloves on, don’t touch the car at all with our clothes or skin). Be very generous with fresh paper towels and the solvent. I usually go over the car twice. Then right before spraying (i.e. with the primer in the gun, which happens to be in my other hand or ready to go) wipe down the car a couple times with the tack cloths. Again be generous about using fresh tack cloths.
Then you’re ready to spray, of course you have to make sure you are not dusty, able to drip sweat, or touch any part of the bare clean metal with you’re skin. This will keep you’re work surface super clan with hardly any dust particles or fisheyes.
