Heres the problem. Every so often I'll go to start my car and I'll get a click when I turn the key over. It doesn't do the click,click,click like when your battery is drained, it just does a single click. Then I'll try to start again and my battery will be so drained it won't have enough juice to start.
Ive cleaned the battery terminals, checked all the connections for looseness. I've tested the battery with one of those eyedroppers with the balls in it and it says my cells are good, and obviously the starter works because most of the time my car starts right up. I tested the alternater voltage and its 12volts + so it looks like its charging.
My guess is either the starter relay or the battery is going. What do you guys think???
