  • SN95 4.6L Mustang Tech
Problem with Drivers side headlight
  • Thread starter Thread starter wytlytning
  • Start date Start date Nov 12, 2004
W
wytlytning
108
  • Nov 12, 2004
The drivers side headlight on my '00 GT is dull. The pass. side is fine.
When I hit the brights nothing happens to the dull drivers headlight at all.
If I flash the brights, it goes out completely. Has this happened to anyone? I hope it is just a bulb.
Thanks
N
n0v8or
604
Rhode Island
Nov 12, 2004
  • Nov 12, 2004
It sounds like you have lost the ground connection to either the bulb or socket. It could be broken within the bulb, but, unfortunately, that would be very unusual.
The light is dim beacause, with the low beam powered, the current returns through the high beam filament (it has no other parh without the ground), so the two filaments are operating in series.
The usual wire colors are:
Lo beam filament - white with green stripe
Hi beam filament - green with black stripe
Ground - black
boomshack
274
Southern Cali
Nov 12, 2004
  • Nov 12, 2004
That happened to me as well. Could be that the housing around the bulb's base needs to be tightened as they tend to get loose on 99-04 mustangs. My mechanic fixed it for me for free and took less than 10 minutes.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
