problem with headlight switch
  • Thread starter Thread starter PeteyAce
  • Start date Start date Jan 8, 2008
PeteyAce
346
Jan 8, 2008
  • Jan 8, 2008
when i have it all the way just the side markers are on. when i have the switch halfway sometimes just the beams come on w/ no markers. i have to get the switch in the middle of turning both on. i replaced the female end and new hl switch but i eventually had the same problem
V
v8muscle
  • Jan 8, 2008
From your description, the switch sounds bad. I know that you replaced it, but with what? a used part or new part?
If it was a new part, I would clean all connections going to that switch, make sure to use dielectric grease when reinstalling. If that doesn't clear it up, I honestly think that you should investigate the computer... I don't know about headlights, but when I removed my alarm system from my mustang, the blinkers didn't work. When I put it all back together, the car would start with no blinkers however. I changed the computer due to starting issues (after some time), and ther frickn' blinkers started working again. I was surprised how many things are controlled by the computer in this car.
But it really sounds like you just have a bad connection. I would firtst try looking at the connections going to the lights and the connections going to the switch.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 8, 2008
  • Jan 8, 2008
I can assure you that the computer on a 5.0 Mustang is not connected to the lights in any way. The only thing they have in common is that they both use electricity to operate.
fastford91
254
Niagara ,Ontario, Canada
Jan 8, 2008
  • Jan 8, 2008
what year is the car? is it a GT or an LX? if its a GT the light switch is notorious for going bad! James
HISSIN50
34
129
Jan 8, 2008
  • Jan 8, 2008
EDIT: I misread the initial post so disregard the following.
Unless your high beams were selected, there's another issue afoot anyhow. The headlight switch only sends raw power - it does not control low or high beam switching.
The MF switch receives power from the hdlt switch and divvies it up depending upon your switch selection. You can have highs and lows come on (with no marker lights) during FTP but the power source for this function isn't even the headlight switch.
Because of the other issue at hand, I would check over the MF switch, its wiring connections (known for backing out of the connector shell) and the wiring (burning up on occasion). The headlight switch might still be an issue but since there are a couple of things going on, I would want to examine both sets of switches and connectors.
Good luck.
PeteyAce
346
Jan 8, 2008
  • Jan 8, 2008
sorry, by beams i just mean the headlight itself w/o side markers
HISSIN50
34
129
Jan 8, 2008
  • Jan 8, 2008
Uh, actually I apologize. I misread your initial post. Forget all that crap in my previous one.
PeteyAce
346
Jan 9, 2008
  • Jan 9, 2008
oo forgot to add, its an lx and the switch i brought was new, but the rewiring kit i used was for a gt, but nothing changed when put it in.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
J
Electrical problem with headlights
  • jeremykrell308
  • Oct 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2025
General karthief
