So I'm having a problem with the Tach that came with the New Vintage USA Performance series mustang DIY kit package. When I turn the ignition to power, the tach needle should jump, but all mine does is ever so slowly creep up to about 200 rpm reading and then stop. When I start the car, the needle will ever so slowly make its way to about 800rpm then stop. When I rev the engine, the needle creeps ups to about 1200-1300 rpm and stops, won't go any higher than that, and when I let off the gas, the needle stays at 1200rpm. When I turn the ignition off, needle stays at 1200rpm. When I disconnect the battery, needle still stuck at 1200rpm. So when I contacted NVUSA, they said to install a 10K ohm pull up resistor between the power and signal wires, did that, same result. Yes, tripled checked to make sure the switch on the rear of the tach is set for 8-cylinder. All the rest of the gauges in the set work just fine, all lights in the cluster work. Not sure what's going on but I never had an issue with my mini-tach or Sun-Pro tach that I have used in the past.http://newvintageusallc.mybigcommerce.com/67-8-mustang-kit-diy-performance-series-black/
