Problems (overheating) after re-installing heads
  • Thread starter Thread starter streetstang67
  • Start date Start date Jun 15, 2005
streetstang67
573
Lexington, SC
Jun 15, 2005
  • Jun 15, 2005
Soon after my cam change (from stock to a compxe256), I broke a rocker arm stud. So I tore the engine top-end off and took my heads to not only fix the stud but also port/polish them; but I did stick with the same size valves. The machine shop replaced the springs to more beefier ones, and I replaced the rockers with roller tipped rockers. After putting it all back together, adjusting the valves and timing good enough to get the car going, I have new problems. Doesn't take any longer than 5 minutes for the car to be running before the radiator cap 'opens'. For some reason, its overheating. Not only that, but several times when I was starting it up, it wouldn't start the first try, but instead it would backfire. and finally, vacuum plugs keep turning up missing. I'm not sure if they popped off when a backfire occurs or if they are just coming off for some reason. I still need to finalize the timing and valve adjustment. What do you think the problem(s) is?
T
TT670
360
9
28
Jun 15, 2005
  • Jun 15, 2005
Id bet you put the head gaskets on backwards and blocked the water passages.
SoCalCruising
2,437
SoCal
Jun 15, 2005
  • Jun 15, 2005
That's the first thing I thought of, too. The backfiring is also bothersome. Is your timing light the kind where you can dial in the total timing you want?
iskwezm
4,159
20
79
Rowland Heights,California
Jun 15, 2005
  • Jun 15, 2005
sounds like timing is off for both problems.
G
grego37
576
Fresno CA
Jun 15, 2005
  • Jun 15, 2005
sounds like timing
are you sure you have the wires in the right firing order, do you have 15426378
hopefully its not the head gaskets
streetstang67
573
Lexington, SC
Jun 15, 2005
  • Jun 15, 2005
Not the head gaskets, I've heard of people putting them on backwards before, so I was sure to get them on right. I don't have a timing light, all I used to set the timing is the harmonic balancer. Assuming it is accurate, I should be set at 12*.
G
grego37
576
Fresno CA
Jun 15, 2005
  • Jun 15, 2005
I reccomend borrowing or buying a timing light before you start tearing things apart.
Double check your firing order on your cam card and at your dist cap and follow each wire to plug to verify.
SoCalCruising
2,437
SoCal
Jun 15, 2005
  • Jun 15, 2005
I asked about the timing light because some allow you to set the timing you want (say 32 degrees) and then you read zero when it is correct. On such a light, if you then read 32 degrees, you are actually at 64 degrees. I don't have such a light, but I have heard of this issue. They say that the motor will run highlu advances, but I would imagine it could backfire.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
