TacBear said:80mm MAF!!
Idle fluctuates from 600-900 rpm--up and down, up and down,up and down,etc.
JonJon said:Does it constantly do that?
When I come to a stop, my car will drop to 600 then rise up to 700-800. When I'm idling it'll do it sometimes too.
I don't know if it's the MAF or not.
I finally called C&L and they told me to check my maf sensor. When I plugged it in I had it rotated at a 9 o' clock position. It needs to be at 12 but may be adjusted slighted if needed. On numerous occassions my car even died at idle. I kept on the gas slightly at lights so as not to look like I was driving a hoopty. Car ran perfect afterwards wait, 12 o'clock relative to what?Joe347R6 said:I had this exact same problem! I checked forever for leaks and even took everything apart and reinstalledI finally called C&L and they told me to check my maf sensor. When I plugged it in I had it rotated at a 9 o' clock position. It needs to be at 12 but may be adjusted slighted if needed. On numerous occassions my car even died at idle. I kept on the gas slightly at lights so as not to look like I was driving a hoopty. Car ran perfect afterwards
TacBear said:It does it constantly at idle.
san~man said:Mine did that too. Took it off and sold it and bought an 80mm LMAF.
