problems with motor
  • Thread starter Thread starter stang88tn
  • Start date Start date Feb 21, 2006
stang88tn
Knoxville,TN
Feb 21, 2006
  • Feb 21, 2006
Hey guys Ive got a problem hope someone can help. I just built a 347 stroker and its running too rich need to know how to tune it . I put 30lbs. injectors with a 75mm maf calibrated for the inj. I put the Holley SysteMaxII system on it with the heads, and the cam,65mm t/b,and 65mm egr spacer I will be changing the t/b and egr to 75mm. the fuel press. is running around 35psi. also where should my timming be set at thanks alot for any advise
vristang
4,933
101
124
Seattle
Feb 21, 2006
  • Feb 21, 2006
Getting any codes?
Old O2s can cause some problems, so can a bad ect.
I always set timing by ear, its a pain to use a timing gun when you still have to listen to how the motor like the new timing setting anyway.
When are you reading the 35psi? With or without the vac attached?
jason
stang88tn
Knoxville,TN
Feb 21, 2006
  • Feb 21, 2006
have no way to get codes and o2 are new 35psi. when running with vacume attached
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 21, 2006
  • Feb 21, 2006
If you have a paper clip, you can get the codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
stang88tn
Knoxville,TN
Feb 21, 2006
  • Feb 21, 2006
hey thanks for the info ill check it out and see what I can do if theirs anymore info out there send it my way where I can get the problem fixed
thanks guys
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
  • dan50
  • Jul 18, 2026
dan50
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
