problems with my 9 in
  • Thread starter Thread starter blue66tang
  • Start date Start date Sep 6, 2004
blue66tang
1,092
Medford, OR
Sep 6, 2004
  • Sep 6, 2004
I am currently putting my 9 inch together but ran into a problem. when i mesh the gears together the ring gear hits the case right where the pinion bearing is. Any ideas. I got my gears and instalation kit from moser. I am pulling my hair out over this. Some thing just cant be right.
R
Ronstang
1,294
Houston Texas
Sep 6, 2004
  • Sep 6, 2004
The taller the gear (higher numerical #) the thicker the ring gear becomes until they finally make contact with the pinion support bearing area. Your only option is to carefully clearance the area with a die grinder so the ring gear does not hit. Take as little out as needed and blend it smoothly with no sharp edges so you don't create a stress riser.
blue66tang
1,092
Medford, OR
Sep 6, 2004
  • Sep 6, 2004
hmm maybe that is just it. The gears are 4:30s, but i thought no mods were needed till they get around 4 60-s. The other2 things that are wierd is that the detroit locker that i have is also ver very close to the support, and the carrier seems to be shifted off center quite abit in the caps.
R
Ronstang
1,294
Houston Texas
Sep 6, 2004
  • Sep 6, 2004
I have been building my own (and all my friend's) 9" rears for about 17 years and I have had to clearance pumkins with gears smaller than 4:30, it just depends upon the individual housing you have and all the components.
blue66tang
1,092
Medford, OR
Sep 6, 2004
  • Sep 6, 2004
well i guess that makes me feel a little better.
I will be back at it tomarrow night then.
Anybody orderd axles from moser. Im not sure how to measure the length i need. Thanks Ronstang
R
Ronstang
1,294
Houston Texas
Sep 6, 2004
  • Sep 6, 2004
Contact Moser and ask how they want you to measure for the axles. More than Likely they want the overall flange to flange measurement of the housing and the distance from each flange to the center of the pumkin opening. That should be all the dimensions necessary but since I don't make axles I would suggest asking Moser.
blue66tang
1,092
Medford, OR
Sep 6, 2004
  • Sep 6, 2004
Yeah the sent me a paper on how to do it, but it lists of like 15 measurements, and its kinda confusing
O well i will jsut call and find out
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
