I just got done changing the sparkplugs, plug wires, dist cap and rotor, coil, and i took off the smog pump and replaced it with a smog pump eliminator. I didnt have the time to take the pipe off the h pipe or the pipe that goes to the heads, i will do this later thouhg, this wont hurt anything will it. after i got done test driving it, i went to pull it into the garage and i heard a noise that sounded something like a ticking noise, it was going tick tick tick tick, constantly at idle, and it would get quicker when u rev it up. My idler pulley was making a squeking noise a while back then it went away. Could this noise be the idler pulley problem coming back. I hope so. Also my car is surging at idle agian. It did this when i bought it and i fixed it by cleaning the maf and all the other sensors and spraying carb cleaner in the throttle body. Im gonna do this again but if this dont fix it, could i just make my car idle a little quicker. I think this would def fix it. my car only idles at 600 right now, i figured i oculd put it to about 800 or 900. How would i go about doing this. Thanx for any help.
Check to make sure that your firing order is correct, things get kind of confusing when changing out the distributor cap.
