  • SN95 4.6L Mustang Tech
Problems with starting
  • Thread starter Thread starter jellowbob
  • Start date Start date Sep 4, 2009
J
jellowbob
Washington
Sep 4, 2009
  • Sep 4, 2009
I was driving my 1996 mustang gt for about 3 minutes and the car slowly died like it was out of gas. I was driving it a second time for like 3 minutes and it did the same thing. when i finally towed it home then i started it and it ran for about 3 minutes again and now all it does is turn over. I changed the fuel filter and it didn't fix the problem. Is there any thing that you guys think could be wrong with? If so please reply asap and tell me all the ideas that you think could be wrong with it. Thanks!
9
91dawg
11
Madras, Oregon
Sep 5, 2009
  • Sep 5, 2009
Check out the fuel lines... any rubber ones that are "rotted" or old and worn? Then check fuel pressure and pump
bhuff30
6,037
35
129
Olathe KS
Sep 5, 2009
  • Sep 5, 2009
You only need 3 basic things for the car to run: Spark, fuel and air, and of course in the correct amounts and at the right time. Check the fuel pressure. Very possible your pump is dying.
hillbilie5.0
38
auburn, ca
Sep 6, 2009
  • Sep 6, 2009
sounds like your fuel pump is taking a dump. check the fuel pressure at the schrader valve on the fuel rail.
MaxedGT
304
Surrey BC Canada
Sep 6, 2009
  • Sep 6, 2009
Make sure also that your tank has gas in it. Your gauge could be wrong and you could be running out of gas.
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
