Thought i had everything back together but i can't figure out why the low amperage starter wire isnt sending out power when i turn the key over. I put a test light on it while i was doing it to make sure it wasn't the starter and nothing.
I also swapped the relays around just to make sure that wasn't the problem. So now im really confused.
I have two possible problems that i can think of:
One, Im hooking the starter wire up to the wrong connector. Does the starter wire connect to the grey w/pink strip wire coming out of the fuse panel under the hood/fender? ITs the only connector that i found that fit what i think is the wire that went to the starter.
two, i missed hooking a harness back up or got one switched around. I have looked over everything and everything besides the abs, speed sensor, reverse light, lights, and airbag sensors are hooked up.
Were exactly does the wire run that was supposed to be hooked up to the starter? To hide things i extened it, but maybe i exteneded the wrong one?
