problems
  • Thread starter Thread starter Graydon5oh
  • Start date Start date Dec 13, 2006
Graydon5oh
215
ARKANSAS
Dec 13, 2006
  • Dec 13, 2006
ok here is the deal its a 86 with a low millage motor. smog deleted and doesnt have o2s on it at the time but used to not have this problem not running right has a lil bit of miss, and when i floow it, it starts by lugging then a couple hundred rpms later it gets better but still not like it should be. replaced the ingnition module helped a lil. new wires and plugs, fuel injectors have low millage, i was wondering if tps or map sensors could be a problem. also i have ha tan wire on the harness comming from the white 10 pin connector that is just hanging there i believe it has power from it i unwrapped the whole harnss couldnt find the other end of it. any ideas would help
V
v8only
2,378
22
49
Dec 13, 2006
  • Dec 13, 2006
You can't just delete the o2 sensors, the computer relies on those to run right. put the damn o2's back in, and you should see a difference
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 14, 2006
  • Dec 14, 2006
O2 sensors are not smog equipment that you just rip off and throw away. They are a must have part in order to keep the car in top operating tune. Without properly working O2 sensors, you will have an overly rich mixture, poor performance and idle problems.
The loose tan or orange wire from the fuel injector harness is likely to be the O2 sensor power ground. Attach it to the manifold or to the back of the heads.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Graydon5oh
215
ARKANSAS
Dec 14, 2006
  • Dec 14, 2006
its wasnt my choice to take them off. there werent on there when i bought the car i have the sensores just havnt got ahold of the the harness, and definitly not having problem with running rich if anything its running lean
89streetbeast
365
horton,ks
Dec 14, 2006
  • Dec 14, 2006
if you got a fuel pressure guage id test the fuel pressure to see if its within specs. should be around or close to 39psi at idle.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
