  • 1994 - 1995 Specific Tech
Prochamber ?
  • Thread starter Thread starter pleasehelp
  • Start date Start date Nov 14, 2004
pleasehelp
686
Poplar Grove, Il
Nov 14, 2004
  • Nov 14, 2004
What is that little tube in the cross section in this picture?? Does it hook up to anything?? Thanks.
G
Green95
28
Idaho
Nov 14, 2004
  • Nov 14, 2004
It is where the smog pump hooks up.
95WhiteVenom
624
Alabama
Nov 14, 2004
  • Nov 14, 2004
yep you gonna have to buy a hose to attach that to the air tube for the smog pump. Then also buy some clamps to hold them on. Its real easy to do.
5.0snake
95
South Eastern PA
Nov 14, 2004
  • Nov 14, 2004
would I have to do to same thing for a bbk o/r H pipe?
9
95redSVT
35
  • Nov 14, 2004
Ive got a Summit H-Pipe on my cobra and i didnt need to get anything special for the smog pump hook up. It was a.....tight fit but mainly because my mufflers arnt where they are supposed to be. To answer the question though: The H-Pipes ive seen also have the smog pump hook-up, will you have to get anything special to hook it up? No idea till i try. Mock it up first, then see.
94GTStang
1,631
Oklahoma City
Nov 14, 2004
  • Nov 14, 2004
What's a smog pump You don't need that.
yellowstang1994
338
  • Nov 14, 2004
Yea it's for the airtube to goto the smog pump. It's pretty hard to take it off the stock H pipe and a little bit harder to put back on the pro chamber. So you will need to utilize your blow torch if you plan on keeping the smog pump on. I have to tell you though, I put my airtube back on and it's a really tight fit, a lot harder to align with it on too. It also brushes on a lot of stuff so it might be a good idea to get a tube. I never thought about that and I think i'll do it when I do my clutch install.
pleasehelp
686
Poplar Grove, Il
Nov 16, 2004
  • Nov 16, 2004
What the hell?! I always read that if you don't have cats you don't need the smog pump. Now I'm confused
SM0k3
580
La Palma, California
Nov 16, 2004
  • Nov 16, 2004
werd....
TrueBlue95GT
966
Connecticut
Nov 16, 2004
#10
  • Nov 16, 2004
  • #10
The only reason the Air pump is even there is to give oxygen to the cats for the reaction to be more complete. If you remove the cats, the air pump is useless.
95Vert
1,785
North Mexico (deep south Texas)
Nov 16, 2004
#11
  • Nov 16, 2004
  • #11
No cats or smog pump here. But let me tell you, the fumes are killing me with the cut offs. I need to throw them off to the side. That pipe, if you decide to bypass your smog pump, just hammer it shut and weld the tip, no problem.
yellowstang1994
338
#12
  • Nov 30, 2004
  • #12
It's true, if you don't have cats on your car you don't really have a use for the smog pump. But take some things into consideration. It's only function isn't to make the cats burn more efficiently, it also ventilates the crank case. The reason I left it in was because it seemed like more of a hassle to remove it and have to put everything back in again when I get it inspected. I do plan on bypassing it though.
M
mackey
1,284
Beverly, Massachusetts
Dec 1, 2004
#13
  • Dec 1, 2004
  • #13
Same thing here
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
