Procomp HEI distributor for SBF (small block ford 289-302, 5.0)
bmxace
9
SOLD
Brand new, still in box, never been installed.
retails for approx. $145.00, asking $100
taken from Procomp website:
GENUINE PROCOMP ELECTRONICS
"DON'T BE FOOLED BY IMITATIONS"
PC6102 THUNDER SERIES PRO HEI
Small Block Windsor
289 - 302
KIT INCLUDES
Pro HEI Distributor
Internal Ignition
Internal Coil
Fully CNC Machined - Polished Housing
Hi Output 65,000 volt coil mounted inside the cap
Superior connection to leads through brass terminals
Chromoly Steel Gear designed to mesh with cast and steel billet cams
Low saturation ignition module offers true spark alignment and instant response
Easy to install and with two flat male terminals on the cap
Just connect the following and you are running
1.12v Ignition
2. Tachometer
located in SLC, Utah
